Peak & Hold Injectors for Honda??
New User
Is voltage or current constant in delivery to the injectors?
I just read that Saturated injectors are usually high resistance, and that
peak&hold are low resistance. Difference in delivery systems is that
peak&hold usually require upwards of 6 amps to work, and saturated injectors
don't require that high a current.
Just wondering if hondas can work this way for long (since obviously, you guys
have been running them). Will something eventually fry?
Is the juice delivered to injectors current regulated, or voltage regulated?
Everyone is putting 10ohm resisters in series. Which I would think would cause
a drop in current.
a drop in current.
Re: Peak & Hold Injectors for Honda?? (echo999)
This is where the resistor pack comes into play.
As for longevity, look at these guys with 200k+ miles. :D
