peak and hold injector question
Im sure ill get bashed for this but im asking anyway i cant find it anywhere else .switching from saturated injectors over peak and holds out of a supra what do i need ? I saw something about a resistor box box are they all the same or do i need a specific one for a certain kind of injectors ? Thanks
https://honda-tech.com/forums/forced-induction-16/using-dsm-injectors-691345/
https://honda-tech.com/forums/forced-induction-16/what-do-i-need-run-dsm-injectors-195834/
https://honda-tech.com/forums/forced-induction-16/resistor-box-wiring-441107/
https://honda-tech.com/forums/forced-induction-16/official-injector-resistor-box-install-56k-buy-broadband-517274/
all links above are in the FAQ in this thread section. Please look over it.
also if your using old factory injectors, I'd highly reccomend getting them cleaned or flow tested, most places charge about $12-16 per injector.
not sure how big supra TT are but I'd say evo560cc should be bigger & also off much newer cars.
GL
GL
PSI does not mean a damn thing. It is all about CFM / lbs per min... This has been well known for decades. Injector requirements are based on horsepower, type of induction, and type of fuel for the main 3. You need to give a lot more information before that assumption is made.
Sassafrass
Oct 9, 2004 09:58 PM
