PCV System, Help/Suggestions?
Old Dec 23, 2008 | 07:23 PM
Jayman_Gsr's Avatar
Default PCV System, Help/Suggestions?
Posted also in Integra forum
OK well heres my delima, I just turbo'd my integra (literally yesterday), I drove over 150 miles (drove easy, untuned as of right now) from greenville to the coast and a bit around town, I only hit a few psi 1-3 just driving normally and when I get to the island I had oil all on my hood and turbo manifold...Apparently my valve cover is leaking (getting a new gasket in the morning), but my question is my pcv valve may be pressurizing the crankcase cause its still set up the way it came from the factory. So I may have this problem and I kinda need to know how to run a catch can to ventilate the case. My plan is to cap the IM port where the PCV system is connected and leave it unconnected until my catch can came in. I was thinking about routing a hose to the intake (pre-turbo) to create a vacuum and act like its supposed to but with this way my turbo/IC/Pipes would be covered in soot after a few weeks? Would it be wise to cap off the IM and run the hose from the PCV to a catch can and put a filter on the valve cover and NOT have the can connected to the intake (pre-turbo) and just let it stay open (both the valve cover and the catch can with a filter to Vent the crankcase), would that be adequate to vent the crankcase?
Sorry if its confusing but any help with this would be appreciated.
EDIT: took this pic from:http://beesandgoats.com/boostfaq/g2icturbo.html#PCV and edited it a bit to show you what I was thinking about doing...
Old Dec 24, 2008 | 10:16 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: PCV System, Help/Suggestions?
i hate to say it, but this dead horse has been covered many times. in the faq's at the top there atleast 3 threads i know of with regards to catch cans and pcv setups.
from the faq's:
Information on Catch Cans and how to construct them: (thanks 95gsrcivic)
https://honda-tech.com/zerothread?id=766009
https://honda-tech.com/zerothread?id=722482
https://honda-tech.com/zerothread?id=687222
https://honda-tech.com/zerothread?id=684673
...and the official crankcase evacuation thread:
https://honda-tech.com/zerothread?id=1199935 (thanks dasher)
DuhQbnSiLo
Jun 26, 2009 08:34 PM
Jayman_Gsr
Dec 23, 2008 06:50 PM
accord99power
May 25, 2008 06:17 AM
s10cky
Nov 20, 2006 12:24 AM
B16Civic93
Feb 26, 2005 01:01 PM
