pauter rods for b16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">Is it true that they come with 5/16 bolts while the GSR gets 3/8's because if thats true then that stinks.</TD></TR></TABLE>They do come with 5/16" bolt but you must understand that this bolt has MUCH more tensle strength than the 3/8" bolt in Eagle Rods or Crower rods. This is an extremely expensive bolt and was incorporated in that rod in order to save weight. Most B16 Pauter rods wind up in Baja class cars that must run a B16 motor. Those guys require a bad *** rod that will take a beating and live and they all use Pauters.
You must remember there are $2 bolts and there are $20 BOLTS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">They do come with 5/16" bolt but you must understand that this bolt has MUCH more tensle strength than the 3/8" bolt in Eagle Rods or Crower rods. This is an extremely expensive bolt and was incorporated in that rod in order to save weight. Most B16 Pauter rods wind up in Baja class cars that must run a B16 motor. Those guys require a bad *** rod that will take a beating and live and they all use Pauters.
You must remember there are $2 bolts and there are $20 BOLTS</TD></TR></TABLE>
so its not just size its strength? I sure hope your right man.
so its not just size its strength? I sure hope your right man.</TD></TR></TABLE>I promise...do not try to second guess Don Pauter and his bolt choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">so its not just size its strength? .</TD></TR></TABLE>
And your girlfriend likes it too!
kidd_drastic
Jan 28, 2006 10:04 AM
