Overheating problems with Golden Eagle sleeves!!!
Old Aug 16, 2002 | 10:38 AM
  #26
DSF's Avatar
DSF
Default Re: Overheating problems with Golden Eagle sleeves!!! (CovertFI)
No. Conduction is the transer of energy through direct contact. Aluminum is a good conductor because it transfer the heat energy easily. Like copper is a good electrical conductor. Iron is good at heat retention and absorbtion.
Old Aug 16, 2002 | 10:40 AM
  #27
JASON77's Avatar
Default Re: Overheating problems with Golden Eagle sleeves!!! (GraphiteAccord)
Ok I have a question, I have a integra ls that has the jackson racing supercharger kit on it. I know that the stock temp gauges are not accurate at all but its all I have at the moment... Anyway after I have done a couple of pulls/runs whatever you call them when the charger is doing its thing the temp gauge stay the same but if I pull over and pop the hood the coolant over flow bottle has quiet a bit more fluid in it than before the runs....
Now could this be from bubbles in the coolant system?? The top coolant pipe is not the proper one it has a slight kink in it (long story) I didn't think it was enough to make a difference and I was planning on replacing it for one that fits properly but now I am beginning to wonder?
How do you properly bleed a coolant system? I have looked (did a search) and didn't find a definite answer? sorry for my ignorance but any advise would be of great help.
Old Aug 16, 2002 | 10:42 AM
  #28
DSF's Avatar
DSF
Default Re: Overheating problems with Golden Eagle sleeves!!! (RGAZ)
Aluminum will cause a chemcical reaction with foods and is banned in all cooking instruments unless it does not come in contact with the food. It has been known to cause cancer. Only AL pans allowed are teflon coated or copper plated. Real cooking pans are made of steel. Many european countries don't even allow AL pans with coatings.
http://www.calphalon.com/about.html
...what I use in my kitchen
Old Aug 16, 2002 | 10:46 AM
  #29
JASON77's Avatar
Default Re: Overheating problems with Golden Eagle sleeves!!! (DSF)
good god that makes me feel better I have a couple pots and pans that are alluminum (pot has no coating) and thought whoops when I read that
Old Oct 10, 2002 | 02:54 PM
  #30
mos's Avatar
mos
Default Re: Overheating problems with Golden Eagle sleeves!!! (b18onboost)
Aluminum conducts heat about 20 times faster than iron. Thats a lot. One of the reasons chefs like cast iron is because it retains heat so well. When you dump in a bunch of cold meat from the fridge, the overall temperature of your stew doesn't change as much as it would with an aluminum pan. Cast iron also takes much longer to warm up though. And then there's the prep work required to seal (with lard) cast iron prior to cooking...pain in tha ***.
One of the reasons it's tougher to weld aluminum is that it transfers the heat away from the weld area so quickly.
Old Oct 15, 2002 | 02:51 PM
  #31
c1hatch's Avatar
the main thing that would cause over heating is a bad cooling system
Old Oct 15, 2002 | 03:05 PM
  #32
mos's Avatar
mos
Default Re: Overheating problems with Golden Eagle sleeves!!! (c1hatch)
Aluminum may be a poison after all. Some scientific studies link aluminum injestion to alzheimers disease. Check the label on your deoderant, buy your beer in bottles, cook in cast iron pots, and use ductile iron cylinder sleeves.
http://www.google.com/search?hl=en&l...er%27s&spell=1
Old Oct 15, 2002 | 03:33 PM
  #33
Quick 200k Mile Motor's Avatar
Default Re: Overheating problems with Golden Eagle sleeves!!! (mos)
Iron also gets corroded easily.
It only takes a few years till water
eats its way through the cylinder.
Old Oct 15, 2002 | 03:34 PM
  #34
Default Re: Overheating problems with Golden Eagle sleeves!!! (Quick 200k Mile Motor)
psyche!
Old Oct 15, 2002 | 04:16 PM
  #35
GZERO's Avatar
Yeah, that's why we use coolant or water weter
Old Oct 15, 2002 | 09:18 PM
  #36
ImportReview
Guest
Posts: n/a
Golden Eagle sleeves have 0 problems with heat...
I can attest...I am only the largest buyer of Golden Eagle sleeves in this Universe.
I have gone through about 40 blocks at least this year alone...and none of them have a problem with heat..at all.
Are you running like a single cam radiator, single core with a 1.8 liter or 2 liter motor?
Did you put in bar's leak and it clogged up your thermostat a little so your not circulating?
Its a problem like that for sure. Check that, flush the system, bleed off all the air, and make sure you run at least a 12" electric cooling fan on it.
The stock fan really is weak, and so is the single core radiators.
I datalogg all the time, and a Fluidyne Radiator is like 20-30 degrees cooler than anything else I have ever seen. Its like the best radiator hands down.
Good luck, and I hope I helped.
Jeff
Old Oct 15, 2002 | 11:33 PM
  #37
GGrahnVI's Avatar
New User
Default Re: Overheating problems with Golden Eagle sleeves!!! (ImportReview)
As long as you keep the temp at 95 degrees C, everything should be fine. Aim for that temp.
AngeloM
Honda Civic (2001 - 2005)
Apr 14, 2025 02:14 PM
microfunk5
Sep 21, 2010 07:45 AM
OldskoojdmDA9
Jun 21, 2009 11:33 PM
Quik89Si
Aug 15, 2002 04:44 PM
