OVERbore folks
Old Feb 25, 2003 | 10:26 AM
RAWB's Avatar
Default OVERbore folks
There has been some recent debates on whether the combustion chambers should be matched to the size of an overbored cylinder. Traditional thinking would say, it should be matched(to eleminate any possible hot spots/detonation)- but I've heard people are running fine with the stock sized c/c's and bigger cylinders. What are you guys using and have you had any problems with it? TIA
Old Feb 25, 2003 | 10:43 AM
boostin b16's Avatar
Default Re: OVERbore folks (RAWB)
bump! this interests me as well!
Old Feb 25, 2003 | 10:47 AM
highbrid's Avatar
Default Re: OVERbore folks (MY"little"T3)
im running an 83mm bore with a stock gsr head, it runs fine.
Old Feb 25, 2003 | 10:53 AM
I Like Boost's Avatar
Default Re: OVERbore folks (highbrid)
b18c with 84mm GE bore with stock head runs fine. Alot of people have made big power with out touching the head.
Old Feb 25, 2003 | 11:22 AM
TurboDANDEE's Avatar
Default Re: OVERbore folks (IMPULSE B18C-T)
most people that have done B20/V-TEC dont really enlarge their combustion chambers and they run fine with lots of power.
Old Feb 25, 2003 | 11:35 AM
2K_TEG's Avatar
Default Re: OVERbore folks (TurboDANDEE)
real heated debate about a year ago here: https://honda-tech.com/zerothread?id=156070
Some say, and I agree changing the cumbustion chamber may hurt performance. I have an 84mm bore with 81mm head and it works just fine.
Kyle
Old Feb 25, 2003 | 11:43 AM
Mr. Vapor's Avatar
Default Re: OVERbore folks (2K_TEG)
wow,
ill be running 83mm and i was always told to bore the head to match.......
interesting. anyone else?
Old Feb 25, 2003 | 11:45 AM
Farnsrocket's Avatar
B18C1 stock, untouched combustion chamber head with 84.5mm block....w3rd!
Old Feb 25, 2003 | 11:47 AM
631 Teggy's Avatar
Default Re: OVERbore folks (NYb16)
How would one go about boring the combustion chamber? i never thought about this potential problem...
Old Feb 25, 2003 | 01:36 PM
autoEXturbo's Avatar
84.5mm gsr block, completely stock gsr head. Runs fine.
Old Feb 25, 2003 | 10:22 PM
accordfreak's Avatar
Default Re: OVERbore folks (autoEXturbo)
if you use the stock bore head with a oversize bore block then what size head gasket do you use??? stock size??
Old Feb 25, 2003 | 10:27 PM
highbrid's Avatar
Default Re: OVERbore folks (accordfreak)
use the size same size headgasket as your cylinder bore size, otherwise your piston may come into contact with your headgasket.
Old Feb 26, 2003 | 10:09 AM
RAWB's Avatar
Consensus = Leave the c/c's alone.
Also, what is the relationship of displacement of a B18C bored to 82mm(1842cc) versus a LS block stock bore(1845cc???) I've noticed LS/turbos still push more torque compared to bored VTEC/turbo setups.
How much of a difference is there between an engine with different bores pushing the same boost on essentially the same head/engine management setup?
[Modified by RAWB, 11:12 AM 2/26/2003]
Old Feb 27, 2003 | 09:16 AM
RAWB's Avatar
B_Swapped93
Mar 15, 2014 11:06 PM
rjay8604
Sep 6, 2004 11:15 PM
B18C_eg
Jun 8, 2004 08:09 AM
jcivicsib20
Dec 26, 2002 12:55 PM
