OverBoostin...
Old Jan 9, 2006 | 11:16 AM
  #26
Civicman86's Avatar
Default Re: (boosted_integ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_integ &raquo;</TD></TR><TR><TD CLASS="quote">get a boost controller
What a useless reply. Boost controllers arent the bandaid for a bad hose. Try again.
Old Jan 9, 2006 | 11:25 AM
  #27
beepy's Avatar
Default Re: (Civicman86)
What manifold are you using? The SSAC manifold and a few others have issues with boost creep. If you are making 7 PSI at 3/4 throttle and only overboost at full throttle, I would imagine it was the wastegate not passing enough gas, which can usually be traced to the manifold.
I know you said that it was boosting fine before.... But, "was goin down the by-pass dropped it to 3rd and stomped it and boost shot to 15psi"... This might be the first time you boosted near redline. I know I don't mash my throttle unless I have a friend in the car to egg me on. 3rd gear above 5000 RPM is where your engine is going to produce the most exhaust, because it is at very high load.
Old Jan 9, 2006 | 08:03 PM
  #28
RH-DTeg's Avatar
its a 38mm tial WG and an inline pro mani.
Old Jan 10, 2006 | 11:10 AM
  #29
EM1_'s Avatar
B A N N E D
well when i drove the car it took boost in first gear and would pop the redline and 2nd gear the same and i took it to 4th with no probs numerous of time..but the next day it just starts over boostin..all vacum lines are fine...he ordered a gasket and we'll try that next if not..we'll go from there
Old Jan 10, 2006 | 03:29 PM
  #30
EM1_'s Avatar
B A N N E D
Old Jan 12, 2006 | 08:30 PM
  #31
RH-DTeg's Avatar
bump
Old Jan 18, 2006 | 08:21 PM
  #32
RH-DTeg's Avatar
i took the top off my WG and it looks like the side of the diaphram is penched, could that have anything to do with it?
Old Jan 19, 2006 | 08:53 PM
  #33
RH-DTeg's Avatar
anyone?
Old Jan 19, 2006 | 08:58 PM
  #34
Hybrid96EK's Avatar
Default Re: (1SickSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SickSol &raquo;</TD></TR><TR><TD CLASS="quote">
i took the top off my WG and it looks like the side of the diaphram is penched, could that have anything to do with it?</TD></TR></TABLE>
yes, this will cause the issue you are having.
Old Jan 19, 2006 | 09:52 PM
  #35
xsi-t's Avatar
i took the top off my WG and it looks like the side of the diaphram is penched, could that have anything to do with it?</TD></TR></TABLE>thats what happen to my 35mm and it did the same ****
Old Jan 22, 2006 | 09:39 AM
  #36
RH-DTeg's Avatar
alright thanks everyone.. could anyone point me to a good place to either buy a new WG or at least a diaphram?
Old Jan 23, 2006 | 09:15 PM
  #37
EM1_'s Avatar
B A N N E D
bump
fuegoski
Mar 5, 2013 05:41 PM
xJJx
Dec 15, 2011 09:08 PM
madracer
Sep 14, 2008 12:36 PM
crucial si
May 31, 2003 08:46 PM
clean
Aug 14, 2002 06:22 PM
