Over boosting.
Old Feb 16, 2002 | 02:35 PM
dangerzone's Avatar
New User
Default Over boosting.
Here is the basic infromation. 93 prelude Si, Drag Gen 2, 550cc, Hondata 2B, 35mm Tial, profac B, JS V2. I finally finished installing the turbo kit. The problem now is I can't control the boost at all. When boosting, the boost keeps going has no sign of stop. I don't think my wastegate is opening at all becasue I can't hear it. I have the compressor port hook up to the Tial side port, probac b "out" to the top port of tial., and tee the bov vaccum for "in".
Old Feb 16, 2002 | 03:01 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Over boosting. (dangerzone)
Try it like this...
1- to intake manifold
2- to compressor port
3- to top of WG
Now, the side port of the WG put that on the intake manifold source.
See if that works, if that doesnt let me know and I'll show you another way.
Old Feb 16, 2002 | 03:02 PM
dbman96's Avatar
New User
Try not using the profec B and see where the WG stops boost on its own.
Old Feb 16, 2002 | 03:26 PM
2000Si-at-UK's Avatar
Default Re: Over boosting. (dbman96)
Just turn off the Profec to see if that's your problem. If so, you might need to change the jumpers on the back of the unit.
Old Feb 16, 2002 | 03:29 PM
dangerzone's Avatar
New User
Art, it still doesn't work. Can you show and another way?. dbman, I had side port drict to compressor port still not luck. Is it possible WG got stuck and it won't open??? Still can't hear the WG open.
before I had profac b, I had side port direct to compressor port, and open the top port, still overboosting
[Modified by dangerzone, 12:30 AM 2/17/2002]
[Modified by dangerzone, 12:31 AM 2/17/2002]
Old Feb 16, 2002 | 03:50 PM
Arturbo's Avatar
Better than steak
25 Year Member
If you have an air compressor try to force some compressed air into the top side port of the WG. See if its opening, but dont put too much pressure in there. Just a quick burst of air in there should do it. You dont have to take the WG off, but you can actually see the diaphram open and close...
art
Old Feb 16, 2002 | 04:03 PM
G's Avatar
G
Do you have the Ball-sack 2bar spring in there? I am not sure, but I think there is some sort of color code to determine spring rates....
Old Feb 16, 2002 | 04:04 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Over boosting. (Arturbo)
How do you have your dip switches?
Per the directions you should have it:
External
1-up
2-down
3-down
4-up
External (when over boosting occurs)
1-up
2-down
3-up
4-down
Old Feb 16, 2002 | 06:29 PM
dangerzone's Avatar
New User
Art is really "Art of Turbo". He just proved it again by solving my problem. I think the WG got stuck or something. I blew it with the air compessor, and reroute the vacumm lines with Art's diagram. The boost satys very nicely on 0.45bar now, no more no less.
I have profac b set
1-up
2-down
3-up
4-down
[Modified by dangerzone, 3:31 AM 2/17/2002]
popwars123
Dec 29, 2011 02:32 PM
g2daturbo
Jun 2, 2008 03:45 AM
pv2dickman
May 27, 2005 05:59 PM
JMinSi2000
Jun 18, 2002 10:12 PM
Lei Siew Long
May 12, 2002 05:43 PM
