Other parts to replace with an engine rebuild?
Old Jul 6, 2002 | 11:58 AM
SilverLudeSi's Avatar
New User
Default Other parts to replace with an engine rebuild?
My engine is being rebuilt right now at inline pro and I am trying to do as much preventive maintenance as possible while the engine is out. So far, majestic honda and inline have suggested I buy the following parts:
-timing belt
-balancer belt
-water pump
-all accessory belts
-cam seals
Is there anything else I should replace at the same time? I assume inline will take care of replacing all the gaskets and such. Any other advice?
Old Jul 6, 2002 | 12:12 PM
int3gra's Avatar
Default Re: Other parts to replace with an engine rebuild? (SilverLudeSi)
get:
ACL bearings.
ProDrive Oil Gear.
GSR/TypeR Oil Pump
Old Jul 6, 2002 | 12:37 PM
Cramerox's Avatar
if your just doing maintanence stuff then this is the list i got, im about to doa tune up soon also.
Spark plugs
Radiatior cap
Radiator hose
i believe there is a gasket for the water pump.
cap and rotor.
spark plug wires.
I guess you dont need all these parts....just depends on how worn your parts are. Might as well tho right? since the engine is out.
Old Jul 6, 2002 | 02:55 PM
VaporTrail's Avatar
New User
Default Re: Other parts to replace with an engine rebuild? (Cramerox)
oil pump, valve stem seals, all new gaskets and seals throughout. That'd take care of all of it. There is no gasket for the waterpump, just some good ole hondabond
Old Jul 6, 2002 | 03:49 PM
New User
Default Re: Other parts to replace with an engine rebuild? (VaporTrail)
I already have the prodrive gear. My oil pump only has 68k on it so I think it should be fine. I had portflow put in new valve stem seals, so I think everything is taken care of. Thanks for the help.
Old Jul 7, 2002 | 10:04 PM
Flamenco-T's Avatar
just buy the upper and lower gasket kit, T-belt and all drive belts, bearings, head studs, oil pump, clutch ( if you need replace or almost time.).....and while you;re at it...add an LSD just for the hell of it..hehehehehe
Old Jul 7, 2002 | 10:11 PM
93LSivic's Avatar
Default Re: Other parts to replace with an engine rebuild? (Flamenco-NA)
To add to all of the above mentioned. I plan on also buying a new timing belt tentioner pulley and spring. That thing makes me nervous as hell--if it comes loose say goodbye to the motor.
New throw-out and pilot bearings for the tranny side of things.
[Modified by 93LSivic, 2:11 AM 7/8/2002]
Old Jul 7, 2002 | 10:55 PM
Flamenco-T's Avatar
Default Re: Other parts to replace with an engine rebuild? (93LSivic)
also those damn dowel pins..hehe
don't skimp out...do it all at one time...it's a PITA to take it apart again and redo it again...not too mention a chance you'll be taking with half *** rebuild...
Old Jul 8, 2002 | 04:43 AM
Ltech's Avatar
If you need OEM parts I can hook you up.
email jasonphan1915@yahoo.com
aim: phan1915
Old Jul 8, 2002 | 05:18 AM
CovertFI's Avatar
Default Re: Other parts to replace with an engine rebuild? (Ltech)
when replacing your oil pump and water pump do yall use just oem or do yall buy from some where else?
Old Jul 8, 2002 | 07:53 AM
apexii's Avatar
Default Re: Other parts to replace with an engine rebuild? (CovertFI)
oem. upgrading the oil pump gear is what's commonly done, you can also upgrade to an electric water pump if you have it like that.
Old Jul 8, 2002 | 10:07 AM
New User
I am going to stick with the same head studs b/c the engine has never been taken apart before and inline said they would be fine. I am getting a quaife at the same time and going from a clutchnet stage 2 to a cm stage 4.
Old Jul 8, 2002 | 11:58 AM
boomslang's Avatar
Get new head studs, or have ARP make you a custom set. I had bad luck reusing old head studs.
Old Jul 8, 2002 | 05:51 PM
Flamenco-T's Avatar
Default Re: Other parts to replace with an engine rebuild? (Inlinefour)
stock head studs tend to "streched" after being taken out once, ARPare meant to be taken out time and time again..
TougeCoupe
Nov 19, 2009 03:56 AM
jdmgeorge
Feb 18, 2004 12:45 PM
deviant1
Dec 24, 2002 06:05 PM
schwett
Apr 24, 2002 08:37 PM
94LSTEG
Jul 11, 2001 09:21 AM
