OT: Help SERIOUS Backfiring!
Old Jun 9, 2003 | 12:58 PM
BoOsTeD_eK's Avatar
Default OT: Help SERIOUS Backfiring!
My car has recently started to backfire horribly when I engine brake. I took out the plugs and they are white which would mean a lean condition to my understanding. Yet my muffler is black with soot which would mean a rich mixture. I know its not the ignition system cuz there is no hesitation whatsoever when I accelerate. It idles rough though. Any one have a clue?
Old Jun 9, 2003 | 01:01 PM
i3oricua's Avatar
Default Re: OT: Help SERIOUS Backfiring! (BoOsTeD_eK)
Maybe your timing belt jumped a tooth. Sorry if that's not a whole lot of help.
Old Jun 9, 2003 | 02:05 PM
Stewie's Avatar
Default Re: OT: Help SERIOUS Backfiring! (i3oricua)
I hate to tell you, but it sounds like your engine needs an overhaul. Backfiring is cause by a lack of compression and that would expain the lean condition. You're probably burning hot because you're consuming alot of oil which increases the combustion temperature by alot, which is why the plugs are white. There is black suet on the muffler because of a combination of raw fuel being burnt in the exhaust and even more so, consumption of oil.
Old Jun 9, 2003 | 04:19 PM
MiraiZ's Avatar
I would say its your timing as well, and i would also check your fuel maps...you might be running lean most of the time and dumping a lot of fuel in some areas.
One last thing could be that your plugs are too cold or not gapped properly..
Old Jun 9, 2003 | 05:49 PM
Mr. Softee's Avatar
Default Re: OT: Help SERIOUS Backfiring! (MiraiZ)
if you are running check valves, check em
dochtwincam
Jun 18, 2017 08:53 PM
wastedyouth2542
Sep 22, 2009 02:21 PM
x4thGenCafe
15
Apr 18, 2008 06:15 PM
Layziebtnh055
Aug 23, 2004 05:06 PM
K1 Racing
Apr 8, 2002 02:50 PM
