Options on Turbocharger Oil Return Routing w/ Mini-Ram style Manifold
Hi, so I have a slight issue. I have a turbo B18C with a GTX2867R. I am runninf .030 oil restrictor and a -8 return line. However, I have a low mount turbo setup with a mini ram manifold. Being that I have little to work with as far as gravity to return my oil, I have recently invested in a Turbowerx scavenge pump. I have recently discovered oil in my charge pipe (its blowing out of the bov) and the only thing that could be causing it is the bad return line angle. Anyway, my question is as follows: Since I am having oil bypass due to oil return, what are the chances that the turbo "seals" are damaged? I was told that as long as I fix the oil return, the oil bypass would stop it would start to seal again and clear itself up. Can anyone give me peace of mind? I only have 500 miles on the new turbo but I am very concerned right now. Thanks!
re: Options on Turbocharger Oil Return Routing w/ Mini-Ram style Manifold
Thats a great pic. I would get rid of that loop. Shortening the line possibly with two 45 degree fittings. Whats your catch can setup.
Edit: I took off the air filter and there is a very small amount of Oil in the turbo itself. No shaft play. Lets discuss more on the catch can though please (this is another issue that needs to be addressed according to the company i bought the turbo from, but they wont reply to me now). So lets discuss that. I just want to look at all angles here and figure out all the problems so I can drive stress free.
I think the turbo is good. Could possibly take the downpipe off and look inside for reassurance. Only real way would be for disassembly, which i dont think you should do that. Id would definitely take care of that drain pronto though. Before it does cause problems. Besides you would likely have a james bond smoke screen. Even then, the smoking would prolly be from rings.
id recommend doin a compression check and/or a leakdown test. Is your catch can filling up.
Ok, ill work with it tomorrow night and see what the results are.
You can fix that oil drain w/o using a scavenger pump.
It needs to be 5/8 or-10AN...-8 is too small.
I would remove that line and fittings completely and put the 1/2" block off bung back in that Moroso pre welded fitting.
Use a barb /push lock style drain hose setup and place the weld bung for the pan where you actually need it. (the fitting angles will be 45 deg and straight, don't use a 90). We keep drain kits for mini ram style/low mount manifolds on the shelf here
Moderator
Co-sign.
Re: Options on Turbocharger Oil Return Routing w/ Mini-Ram style Manifold
So a 45 worked for you, but mine is lower than yours. Here is what I am dealing with. The 45 would make my line below the oil level and have to push it uphill again to the new bung.
Moderator
OMG.. I recant my statement. you're stuck with this for a bit. Autoworks / Spoolin' used the same style manifold that sits low, (as shown in the examples,) but not that low, to a point where the turbo is below the frame.. That's bad news, sir.
It is too low now looking from that angle. You are in a "scavenger or new manifold" scenario for a proper oil drain angle. I saw one of those pass through here maybe a year or go (the only one I'd ever seen in person like that); which was the first I had seen someone make that was just unworkable w/o doing a pump setup.
Getting away from the AN fittings and going to barb w/ a Mini allows for a longer/more workable hose.
Moderator
Ok well thanks so far for the help guys. I really appreciate it. Its unfortunate, but I either use my TurboWerx scavenge pump, or redesign my manifold. I am fine with either way. I just want it right and able to drive without worry. Would the scavenge pump be worth the effort though, or should I just plan on building a new manifold. Apparently my fabricator didn't compensate for the return line lol.....
Turbo drain outlet to reservoir to scav. pump to pan maybe? That is going to get tricky...also why the earlier mentioned scenario left w/ a new manifold. Less $, less plumbing, less headache.
Moderator
So, dunno.. But at least Xperience is getting more this.... Experience. (ok, ok, bad attempt, I know.. )
In theory, but not enough length of room for the scav pump to work with. Those need distance with a length of line to work from most (At least the ones I've dealt with. (Mainly V8 Twin turbos with low-mounted manifolds for over 1500whp, or some Custom "ariel atom" styled rear-engined setups. )
Personally I'd just bypass all the scavenging pump and extra plumbing, and just replace the manifold with a better mini-ram. Way less of a headache IMO, and I bet by the time it's all said and done the slightly higher cost of a different manifold would be well worth it.
Just .02
Greg and Shodan are the local wizards. Both are chock full of great experience and advice.
Just .02
Just .02
Leak down test results. 98% on cylinder 3 and the rest were 100. And downpipe taken off and no oil
Just .02
Just .02
I agree, a new manifold will be the best solution
Moderator
A new manifold with a Go-Autoworks GT return line kit would be most optimal, and will help you place the return bung in the right central area using a high pressure hose over the SS line. It just allows for more flexibility
Another option if you have some fabrication skills or want to source it out... is to rotate the turbo return line pointing towards the passenger side and construct and can (rectangle shape) for the return to fill directly off the turbo (inlet of can on the side)... then place a drain bung on the bottom of this new can and go with a full flow 45 degree which will then go to the oil pan.... the drain fitting on the bottom of the can must be as large as possible along with the drain hose.
