OPINIONS PLZ
Old Oct 16, 2001 | 03:02 PM
SpoonCivic's Avatar
New User
Default OPINIONS PLZ
Well its that time..my B18C5 block is being built to handle my thirst for more boost.
My goal is to make 500+ whp and im debating on two setups i'll list them, and I hope u guys can take the time to comment on which one is better, and what other setups u guys might have in reccomendation:
1).
Use my B18C5 Block.
Resleeve Block with Ductile Iron Sleeves
Knife-Edged, Balanced Crank
Crower Rods
JE 84mm 9.5cr Pistons
Endyn 2.0L headgasket with VTEC oil passage
Deck Plate to 2.4L
2).
B20 Block
Balanced and Knife-edged crank
Block Guard
JE 84.5mm 9.5cr Pistons
Crower Rods
VTEC oil squirters
Deck Plated to 2.4L
Id also be interested in ur guys inputs on compression; i wanna boost 20+ on 94 octane. Im using a Haltech E6K. Should I go to 10cr or 9cr? Also would a stroker kit be a good idea aswell?
thanx guys,
hopefully i can get some answers soon cuz I wanna boost bigtime
[Modified by SpoonCivic, 1:45 AM 10/17/2001]
Old Oct 16, 2001 | 04:46 PM
SpoonCivic's Avatar
New User
Default Re: OPINIONS PLZ (SpoonCivic)
ttt
Old Oct 16, 2001 | 05:13 PM
DIRep972's Avatar
Smarter than you
running 20psi on 94 octane is impossible. the compression ratio would have to be like 7.5.1-8.0:1
do everything you can think of to build your motor for 500hp, run 9.0.1 compression ratio and 20+ psi on RACE gas only.. but remember once you are making that much power you have to get it to the ground
this is the hard part.. good luck with your project
brharris777
Feb 11, 2011 08:56 PM
B16afmaxt
Nov 11, 2009 04:27 PM
Bulldogg83
Jun 8, 2004 05:30 AM
Bspec18
May 25, 2003 11:08 PM
SpoonCivic
Oct 16, 2001 04:43 PM
