only made 335whp on my z6?
i only made 335whp and 277 tq on my built zy sotck head .. i have a t304e 57trim 50.63. at 24psi.. on c16,.,.,. is this the reason i didnt make more .. the turbo size... if so i wanna get a sc34.. let me know so i dont go drop 800 bucks for nothing
Re: only made 335whp on my z6? (IT'S ME DAVID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID »</TD></TR><TR><TD CLASS="quote">nice avatar that saUCE IS DA BOMB...</TD></TR></TABLE>
No ****! Mix some of that in with regular cayenne pepper sauce and butter for excellent wing sauce.
Re: (g2turbo)
What the hell is a "built Z6 stock head?"
That turbo should have absolutely no problems putting out more power.
More info on your setup would be nice...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IT’S ME DAVID »</TD></TR><TR><TD CLASS="quote">nice avatar that saUCE IS DA BOMB...</TD></TR></TABLE>**** Sauce?
Who is Mr Robot?
Re: only made 335whp on my z6? (SynTeg)
its a z6 people. that power sounds about right for that turbo and motor combo.
youll make less power with an sc34
24psi + c16 =335whp and you think thats normal?
pump gas + 24psi = 335whp might be normal....
course i aint familiar with z6 numbers but i have seen plenty of d16s make more power than that on PUMP gas and LESS boost. Unless the z6 head just flows like **** then somethin is up imo
Re: (turbotime)
Id like to know what type of dyno these numbers were measured on?
Gitwidit's SOHC built motor made 400whp and 304wtq on a SC61 on around 30 lbs of boost... on a Mustang dyno. Id say your numbers are a little low but nothing to get all worked up about. Post the dyno.
thats not even close to being remotely normal...a skim over the SOHC boost thread will tell you that.
the vitara sets up running 22 psi are over 400 hp....
Who is Mr Robot?
Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">i bet there are more problems than we know about</TD></TR></TABLE>
Re: (wantboost)
Drag manifold Vitara setup was running 22psi on 100 octane putting down 405 with that same turbo.
Kelly made 441whp on a stock port/sleeve Z6 with a 59300 cam, topmount, and I believe 27ish psi on the same turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">its a sohc. and i bet there are more problems than we know about</TD></TR></TABLE>
Wake up, SOHCs making 400 aren't anything new now. That turbo at that PSI on C16 should be seeing something similar.
Again, setup?
Again, setup?
that **** is awesome, my asian buddies got me eating that stuff.
Re: only made 335whp on my z6? (bmw626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmw626 »</TD></TR><TR><TD CLASS="quote">
that **** is awesome, my asian buddies got me eating that stuff.</TD></TR></TABLE>
rooster sauce mnmnmn yummy..... esp with some Pho noodles
Re: only made 335whp on my z6? (hitatree.at125mph)
Im not tryin to sound like dumb^** but just try this out before you spend A LOt on a new turbo.
Buy a SSAUTO T70 for about $300shipped. They come with a large twin scroll 84AR turbine. Try that turbo out and see if it helps before dumping a lot into a turbo that isnt that much bigger than what you already have. Your gonna see good gains by upping your turbine AR, and if you can just up your current one then try that. Try around an 80-85AR. Compressor size can and will help but Major gains are from increased turbine AR's and larger turbine wheels.
BTW this isnt a joke, the turbo works fine and for the price is worth tryin to see if a larger turbo is what you need. Just a cheaper option you can test out.
Good Luck.
Good Luck.
Hell ya it is! My ex used to make stuff with that kind of sauce all the time. Where the hell can you get that stuff and I can't remember what it is called?
its a built bottom end with stock sleeves stock z6 head and y8 intake mani.. no boost leaks im making 22 psi by 4900 rpm with open dp.. we upped the boost and it made less power we upped the timing mad eless power.. power was falling off after 6k so we leaned it out to 12.4 and it gained 20whp.. ???? i just dont get what the deal is.. ohh and i used msd 6al and blaster 2 coil at first it was only making 250whp and missing at high rpm moved back to stock and it made the 335 whp...
