OMNIPOWER VALVTRAIN
Old Oct 19, 2006 | 10:20 AM
lsturbo9's Avatar
Default OMNIPOWER VALVTRAIN
WILL IT WORK ON FI VALVE STEM LOOK KINDA THIN
HOW MUCH BOOST AND HOW HI CAN I REV
Old Oct 19, 2006 | 10:23 AM
lsturbo9's Avatar
Default Re: OMNIPOWER VALVTRAIN (lsturbo9)
ENYONE
Old Oct 19, 2006 | 11:03 AM
lsturbo9's Avatar
BUMP
Old Oct 19, 2006 | 12:16 PM
M.A.R.C.'s Avatar
Default Re: (lsturbo9)
I run them. #'s in sig. I don't revv past 9k though.
Old Oct 19, 2006 | 01:09 PM
lsturbo9's Avatar
Default Re: (M.A.R.C.)
HOW MUCH BOOST
Old Oct 19, 2006 | 01:12 PM
M.A.R.C.'s Avatar
the 511whp was 23psi
Old Oct 19, 2006 | 01:13 PM
lsturbo9's Avatar
YOU THINK THEY CAN TAKE 28 TO 30 PSI
Old Oct 19, 2006 | 01:17 PM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsturbo9 &raquo;</TD></TR><TR><TD CLASS="quote">YOU THINK THEY CAN TAKE 28 TO 30 PSI</TD></TR></TABLE>
i have the gen2 springs... which have a softer seat pressure. if i recall... hybridhatch99 or whatever his name was: https://honda-tech.com/zerouser...32783
was making close to 800whp on his setup on the Gen1 springs.
Old Oct 19, 2006 | 01:18 PM
lsturbo9's Avatar
THANKS
Old Oct 19, 2006 | 02:48 PM
Blind-Fashion's Avatar
I made 603whp reving to 9800 rpm's with them. And at the track Powershifting hitting 10,200. but I'm only running R cams. 28-29 psi
Old Oct 19, 2006 | 04:45 PM
shortyz21's Avatar
Default Re: (Blind-Fashion)
wow thats good to hear.
i wouldnt even consider running anything on my car from a company who made coilovers that fall apart..
just my .02$ heh
Old Oct 19, 2006 | 04:58 PM
Jared's Avatar
Default Re: (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">wow thats good to hear.
just my .02$ heh</TD></TR></TABLE>
thats a typical honda-tech uninformed statement
Old Oct 19, 2006 | 07:11 PM
crazi92hb's Avatar
i had the first gen in my all motor setup and i rev'd it to 9500 all the time. just my 2 cents. i would buy again
Old Oct 19, 2006 | 07:23 PM
Sound Streamin''s Avatar
I would buy again but I'd get aftermarket Valves. I snapped a valve with mine and destroyed the motor revving to 8400.
Old Oct 19, 2006 | 07:46 PM
Thurman Merman's Avatar
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">
thats a typical honda-tech uninformed statement</TD></TR></TABLE>
So true.
Tell me my friend, have you ever ran Omni coilovers on your car and had them fall apart?
Old Oct 21, 2006 | 07:21 AM
crazi92hb's Avatar
i still havent seen a set of there coilovers falll apart that were installed properly people do half a$$ed **** and thier cars fall apart.
Old Oct 21, 2006 | 12:13 PM
eg:R's Avatar
i'm running full omin valvetrain on boost. bounce off rev limiter 8.5k all the time.
Old Oct 21, 2006 | 02:36 PM
Hybrid96EK's Avatar
Pressure in the cylinder won't effect the life or functionality of valve springs or retainers.
Old Oct 21, 2006 | 03:30 PM
Runnerdown's Avatar
Default Re: (Hybrid93Eg)
thats true but they are trying to snap shut with 28-30 lbs against them. and when they are fully closed there is 28-30psi behind it.
Old Oct 23, 2006 | 07:24 PM
Jared's Avatar
Default Re: (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote">thats true but they are trying to snap shut with 28-30 lbs against them. and when they are fully closed there is 28-30psi behind it.</TD></TR></TABLE>
but look at compression pressure compared to what is in the manifold. not even close.
Old Oct 23, 2006 | 08:49 PM
BoostedGreddy's Avatar
dam they look like i might pick some up then ..
Old Oct 23, 2006 | 10:16 PM
mec. pedri's Avatar
rev 70lb spring with rev titanium retainers
and you're good!
ochsy03
Nov 4, 2005 07:33 PM
BoOsTiN Dc2
Aug 6, 2005 09:55 PM
SoHc84
May 27, 2005 08:25 AM
turbotime
Aug 15, 2004 10:44 PM
TurboEG6
Feb 9, 2004 10:41 AM
