OmniPower 3 bar MAP sensor calibration trouble
I am trying to install an Omnipower 3 bar MAP sensor and calibrate it using Hondata S300. I went under the MAP and setup for custom setting, I entered 617 for scalar and an offset of 11, as per Omnipower instructions. This results in a rough idle. Is anyone using this current sensor, or experienced any similar problems calibrating a Map sensor? any help is appriciated. by the way this is on a B series engine
I also have an omni 3 bar map sensor but i was wondering if you could help me out.
i am running an s200. is it set up the same way an s300 is. im having boost problems around 5500rpm +. it seems like it loses boost/power after 5500rpm. iv narrowed it down to the map sensor. i would really appreciate it if you could help, thanks
I'm not trying to jack this, but you may want to try this:
Scolar: 838 mbar/volt
Mbar: 31
and under map sensor settings you want to high light the Hondata/Omnipower 4bar.
Good luck and let me know how did that work for you.....
Exactly, I set it for the hondata/omni 4bar and it worked perfect.
quickchris
Jul 28, 2006 09:47 AM
