OK, which one??? Need help...
Old Jun 6, 2002 | 08:19 PM
JRSCCivic98's Avatar
Default OK, which one??? Need help...
Don't be biased cuz you see Drag as a word... hehe
My car is a 98 Civic EX D16Y8.
Should I get this turbo kit? http://www.exospeed.com/turbo.htm
Or should I get this one? http://www.apexi-usa.com/intake_turbo.asp
I already have 440's and PowerFC w/Commander +pump for fueling... and other things... so that's not really a problem...
Oh yeah... Drag=$3015 Apexi=$3032
Prices are with intercoolers.
So, which is it?
Please help.
[Modified by JRSCCivic98, 5:21 AM 6/7/2002]
[Modified by JRSCCivic98, 5:22 AM 6/7/2002]
[Modified by JRSCCivic98, 5:24 AM 6/7/2002]
Old Jun 6, 2002 | 09:10 PM
inspyral's Avatar
Default Re: OK, which one??? Need help... (JRSCCivic98)
I like the fact that the A'PEXi unit is bb, but it's a smaller turbo...
I'm conflicted
Old Jun 7, 2002 | 06:14 AM
Yes, it's bigger then a Greddy kit (ewww), but not as big as a Drag T3T4. I just don't want hella lag on my SOHC motor. If I had a B18 in there first, then I'd definatly get a DRAG!
Well, it's either one of these turbos or even pondering doing a GSR Swap. But I don't want to spend too much on just a swap and GSR's a still a bit hard to find. Anyone know of a good place to get a GSR w/o ecu and axles... Basically just the Engine. Hell, I don't even need the intake manifold. Gona use a Skunk on it anyway. Can't run Dual Runners with PowerFC w/o changing harnesses.
Anyway, enough blabeling...
Old Jun 7, 2002 | 07:46 AM
sushibug's Avatar
get the apexi.... if you've done your research on it you'd know its got a lot of potential. it makes the hp of a greddy turbo tuned... untuned (fmu setup) at the same psi.
Old Jun 7, 2002 | 08:24 AM
dustin's Avatar
Default Re: OK, which one??? Need help... (sushibug)
If you want to make real power, get the drag kit.
Old Jun 16, 2002 | 01:15 PM
crucian's Avatar
I would say get the bigger turbo and spray it with some laughing gas for less lag!!!
Daysleeper
Oct 12, 2002 10:23 AM
MCNease
May 2, 2002 02:51 PM
AB16A2T
Apr 23, 2002 12:39 PM
LS-T
Aug 31, 2001 08:41 PM
