Ok newb needs some help again
Old Apr 23, 2002 | 06:34 PM
Anubyss's Avatar
Default Ok newb needs some help again
So, I ordered JE Pistons 9:1 and some Eagle rods. The question is, I was told to use emory (sp?) cloth to smooth the sharp edges then clean the pistons. What is an emory cloth and can I just pick it up at Pep Boys? Then I am suppose to clean it to make sure all residue is removed. What solvent am I using to do this? Well that's about all the questions I have (for now anyway hehe). Thanks guys.
Eagle Rods
JE Pistons 9:1
Old Apr 23, 2002 | 06:36 PM
b18bturbo's Avatar
Default Re: Ok newb needs some help again (Anubyss)
emory clotch is very fine clotch you can get at any ahrdware store or craft store. Second off the solvent you need to clean with is alky rubbing pads works well.
Old Apr 23, 2002 | 06:56 PM
Anubyss's Avatar
Default Re: Ok newb needs some help again (b18bturbo)
Ah thanks. Just rubbing alcohol will do? I think I have that somewhere. But how can fine cloth get out the sharp edges?
Old Apr 23, 2002 | 07:26 PM
saso
Guest
Posts: n/a
Emry is another name for sanding paper. Good engine builders smoothen the sharp edges to eliminate hot spots. I,m not sure what grade paper they use though.
Old Apr 23, 2002 | 07:34 PM
Anubyss's Avatar
Ok I have some ultra fine (600 grit) and super fine (400 grit) at home. I guess I can start with those and see how it works out. I hope I don't screw something up.
cloviskilla
Nov 3, 2011 03:34 PM
cloviskilla
Nov 3, 2011 03:33 PM
EJ8 GSR-T
Mar 5, 2006 02:05 PM
boost fed ls
Jan 30, 2005 06:32 PM
