Ok, need a quick track tip..
Old Nov 29, 2001 | 08:17 AM
VTC_CiViC's Avatar
Default Ok, need a quick track tip..
I'm hitting Moroso this Friday, so I'd like to know from you guys what you think would be better, should I run out of my cat, or right off the DP? I'm still usuing the stock GReddy straw sized DP, stock cat and stock EX catback so I'm pretty sure i'm choking the turbo, and since this is just for the track I figured I could unbolt the exahust but I'm not sure if I should leave the stock cat on or remove it too. Whatever it is I do, I just want to ensure there are no detremental effects to the car, just the noise
BTW my friend (he's an ASE Master Tech @ MB) told me I might have problems overheating if I remove the exahust and run like that all the way up to West Palm Beach from Miami, seem right to you?
[Modified by VTC_CiViC, 12:18 PM 11/29/2001]
Old Nov 29, 2001 | 08:19 AM
newsense's Avatar
New User
Default Re: Ok, need a quick track tip.. (VTC_CiViC)
i would take the cat off...
Old Nov 29, 2001 | 08:21 AM
TurboSedan's Avatar
New User
Default Re: Ok, need a quick track tip.. (newsense)
Take the cat off dude.
Old Nov 29, 2001 | 08:22 AM
VTC_CiViC's Avatar
Default Re: Ok, need a quick track tip.. (97CivicFerio)
Ok so run with just the DP in place.. sounds right? Any problems other than noise with running like this for the day?
Old Nov 29, 2001 | 08:43 AM
D-Man's Avatar
it could lean out engine,this could be bad or it could be good,all depending on how your engine is tuned.
Old Nov 29, 2001 | 08:56 AM
ForcedAccord's Avatar
Texas B*tch!
Default Re: Ok, need a quick track tip.. (D-Man)
No cat, just be sure to put it back on so you don't get some sort of ticket.
Old Nov 29, 2001 | 10:43 AM
Rob03Pro5's Avatar
Default Re: Ok, need a quick track tip.. (ForcedAccord)
Go with some friends.. and take off the exhaust at Moroso. Or, take it off at home and drive slowly to Moroso.. gonna take more than 1hr and half probably.. heh.
Old Nov 29, 2001 | 02:30 PM
bQQsted hybrid's Avatar
Default Re: Ok, need a quick track tip.. (Rob92SC)
I don't understand, why do you have to drive the car all the way to the track without the exhaust? Just take it off at the track.
Old Nov 29, 2001 | 03:04 PM
JM Performance's Avatar
Default Re: Ok, need a quick track tip.. (bQQsted hybrid)
Cuz it'll be hot as ***** at the track.
Old Nov 29, 2001 | 04:54 PM
AlphaKennyWun's Avatar
Take the cat off it slows the car down too much....Also the turbo makes the exhaust a little quieter....just dont stop at too many lights...If you travel highway thats good...the other cars around you probably not even notice if you keep revs low Good luck!
b18LS
Jul 18, 2007 08:24 AM
gulftiresinc
Sep 19, 2004 08:44 PM
Nate B
Sep 19, 2002 09:49 AM
VTC_CiViC
Nov 15, 2001 01:37 PM
