Ok, it's running again BUT...
Old Feb 23, 2003 | 02:52 PM
Smashback's Avatar
Default Ok, it's running again BUT...
it's running, but in limp mode and REALLY rich...acts like a 302 with a gigantic cam, which I assume is from being so rich.
96 Civic, using stock DX harness modified with connectors for the LS
1995 LS, skunk2 intake mani, B20 cams, cam gears on stock setting
Fuel pressure set at 35 psi w/vacuum
dsm 450cc freshly cleaned
hondata w/basemap from sgt
o2 sensor connected to primary o2 sensor connector on harness
I tested the 3 bar map, seems to be hooked up right. Switched o2 sensor connectors for giggles, same thing...lowering the fuel pressure of course helps but it's still in limp. Disconnected battery to reset ECU but chk eng light comes right back.
Is there a way to see the codes on an OBD2 car converted to OBD1?
Also does OBD have I crank fluctuation sensor? I didn't think so but just wanted to check.
Old Feb 23, 2003 | 02:54 PM
Tinker219's Avatar
Default Re: Ok, it's running again BUT... (Hatchblack)
Dude, you can check the codes the same way as OBD2...with the jumper harness...at least mine worked, and I have the conversion harness....
[Modified by Tinker219, 6:54 PM 2/23/2003]
Old Feb 23, 2003 | 03:27 PM
Smashback's Avatar
Default Re: Ok, it's running again BUT... (Tinker219)
Alright, first time I've done this. I'm assuming the light we're looking at is the SRS light?
This one comes on for about 5 seconds, goes out, then comes back on solid ... doesn't seem right.
Old Feb 23, 2003 | 03:36 PM
Smashback's Avatar
ttt come on guys....i want to drive this puppy it's been like 4 months!!!
Old Feb 23, 2003 | 03:57 PM
SpoolinSol's Avatar
On mine the Engine light flashes....
Old Feb 23, 2003 | 04:03 PM
swrdply400mrelay's Avatar
I'm guessing you haven't tuned it with a wideband yet? What code is it throwing?
Old Feb 23, 2003 | 05:05 PM
Smashback's Avatar
Default Re: Ok, it's running again BUT... (SpoolinSol)
So the one that flashes is the actual check engine light?
Old Feb 23, 2003 | 05:29 PM
zojirushi's Avatar
yes the check engine light flashes, u count the number of flashes to get the code
Old Feb 23, 2003 | 05:34 PM
rOby's Avatar
Default Re: Ok, it's running again BUT... (zojirushi)
dpepnding on how many codes u have will determine how mnay flashes u will see. check out c-speedracing.com and itll show u the code book to count it.
Old Feb 23, 2003 | 05:45 PM
B20-T's Avatar
Default Re: Ok, it's running again BUT... (rOby)
Long =10
short=1
Old Feb 23, 2003 | 07:13 PM
Smashback's Avatar
Damn...the check engine light doesn't flash...ugh.
Old Feb 23, 2003 | 07:36 PM
bruthaboost's Avatar
Just checking: So you jumper'd the green connector and turned the key to the ignition [not start] position and cel flashing?
Old Feb 23, 2003 | 07:37 PM
http://www.jdmfan.com/technical/other/troubleshoot_dtc/
HTH
Old Feb 23, 2003 | 08:10 PM
UberTeg's Avatar
Are you sure its in limp mode? Is the CEL on? And is the basemap you got tuned for 450's?
Old Feb 23, 2003 | 08:17 PM
DIRep972's Avatar
Smarter than you
check the codes for the check engine light and come tell us what is is.
long= 10
short= 1
after that, do u happen to know if SGT made the base map for a 3bar map sensor? also, do u know if he set it in open loop? open loop and the car will run crappy as hell before its tuned. check the codes first so we can see where to go from there.
[Modified by DIRep, 9:18 PM 2/23/2003]
Old Feb 23, 2003 | 08:19 PM
JT's Avatar
JT
Do you have Hondalogger? If so, the error code tab should provide the error information.
Old Feb 23, 2003 | 08:36 PM
Smashback's Avatar
Default Re: Ok, it's running again BUT... (bruthaboost)
Yeah, jumpered and on not started, but I'm gonna try again.
I gave him all the specs including 3 bar map and dsm 450's but I don't know about the open loop deal Chris. I'll see if I can get ahold of him to see.
I've been thinking that it might be that he didn't set it up for one or both of those, mistakes happen but I doubt it...can't be that simple for me.
Interesting:
I was just telling Tony. I pulled out the OBD1 and Hondata and stuck a stock Civic EX 1997 ECU in there, even with the 450s it ran better and didn't go to limp mode.
Swapped back to OBD1 again, stuck the original Hondata chip in there that was supposed to be setup for 720's and not sure what MAP, but it freaked out bad, the fuel pump relay was clicking and buzzing and the fuel pump was turning on and off...all this happened just by turning the key to the on position!
Old Feb 24, 2003 | 02:36 PM
Foozball26's Avatar
that sounds fucked up chris.
If you're talking about my base map it was for a 3 bar map
can you get it to tony to see what hondata is saying on the laptop?
Old Mar 1, 2003 | 11:03 AM
Smashback's Avatar
Default Re: Ok, it's running again BUT... (foozball-26)
I think I am starting to figure it out. It looks like you plugged in the EEPROM in backwards you bastard. I think that messed up the original chip. I never thought about it and plugged the new chip in the same way, and it ran, but like *** so I'm sure it was running off a backup map as it says in the Hondata manual.
Now when I flip the chip around the right direction, it won't start and I've tried every timing setting on the clock, so I'm thinking that the new chip might have been erased. I need to find my rom burner...I think it will probably burn this type of chip. Do Hondata rom files just come in standard .bin format?
Old Mar 1, 2003 | 11:24 AM
UberTeg's Avatar
haha, holy ****, you literaly fried the eprom if you put it in backwatds. Always make then otch on the chip face the wiring harness You didnt notice the massive amount of heat? I did that once on accident and smelled burning plastic. You could have quite possible fried some circuits on your ecu as well.
Old Mar 1, 2003 | 11:31 AM
Arturbo's Avatar
Better than steak
25 Year Member
Chris, who put in the EEPROM for you?
Old Mar 1, 2003 | 12:01 PM
Smashback's Avatar
Default Re: Ok, it's running again BUT... (Arturbo)
I got it from foozball-26 He had bought it and I assume he did the soldering..
I know the Hondata manual says it either erases or kills the EEPROM, I'm thinking that his,the first one is dead but I'm hoping that mine is just erased.
And yeah, I'm REALLY hoping the ECU is ok!
[Modified by Hatchblack, 9:02 PM 3/1/2003]
Old Mar 1, 2003 | 02:19 PM
Foozball26's Avatar
nope, I didn't install it. Tony did all the soldering and chip install.
I brought him all my stuff straight from 2k_teg.
Ask him, he should have the stuff to burn a new base map for ya.
[Modified by foozball-26, 5:21 PM 3/1/2003]
Old Mar 1, 2003 | 02:52 PM
Smashback's Avatar
Yeah, I talked to him last week. I was gonna go Wednesday but then all this damn weather
Texas sucks!
Old Mar 1, 2003 | 03:25 PM
Foozball26's Avatar
yea it sucks, I just got some new tires (azenis) and it freezes over the same day, so I havent had a chance to try them out fully yet
All I know is that they are rubbing and need to raise my coilovers now, I swear i hit a little nipple on the road and scratch is all I hear.
dj211855
Engine Management and Tuning
Aug 28, 2011 11:52 PM
flatblacksleeper
May 8, 2009 11:27 PM
ThA IntegrA HI
10
Oct 12, 2008 02:05 PM
dogfood
Oct 6, 2004 04:45 PM
Maxime
May 17, 2004 11:30 AM
