is it ok to drive without O2 Sensor
Old Jun 26, 2009 | 04:05 PM
1DayIllBFast's Avatar
Default is it ok to drive without O2 Sensor
Here is my question. Is it ok to drive without an O2 Sensor plugged in? My new Downpipe does not have an O2 bung to plug in my sensor where my old headers did. I will only be driving from my shop to the tuner which is about a 20 minute drive. It might be a dumb question but will i be ok until he makes one for me?
Old Jun 26, 2009 | 04:28 PM
Default Re: is it ok to drive without O2 Sensor
Actually it looks like i ahve 2 O2 sensors. One before the cat and one after. Are both of these O2 Sensors or not?
Old Jun 26, 2009 | 04:46 PM
omgwtfbbq's Avatar
your o2 sensor controls your air/fuel @ your ecu, after your car reaches operating temp. Before that, it runs off a basic fuel basemap...theoretically, you can drive without one and your car will run off your basemap, and you will have a CEL.
Since you are going to a tuner, your car will be tuned to a set fuel basemap, rendering your stock o2 useless, and they can then disable your O2 sensor...I'm hoping that you will be using your stock injectors, and disconnecting your charge pipe so that you aren't boosting to your tuner....it'd be sad to hear that you blew your motor on your short drive to the tuner.
Old Jun 26, 2009 | 06:21 PM
Well i have a hondata s300 taht i will be loading a basemap for my setup with 650cc injectors. But no im not disconnecting my charge pipe or having stock injectors driving to my tuner but im also going to be granny shifting and already have a basemap good enough to get me there. I was just wondering if it is safe to drive to the tuner without my O2 sensor hooked up which from what you said it is.
boosted civi
Mar 10, 2009 07:15 PM
mxl36o
Aug 4, 2006 06:09 PM
budget
Jul 17, 2006 08:00 PM
bgoetz
Jun 8, 2005 07:50 AM
