Oiling issues on DSM turbos...
Old May 15, 2003 | 12:56 PM
fsp31's Avatar
Default Oiling issues on DSM turbos...
Given the size of the stock oil feed line for DSM turbos (14b's, and T25's) it seems like maybe the oil pressure (on DSM's) is dramatically lower than when we plumb in an oil feed line on our Hondas from the oil pressure sensor. Not to throw names around, but Kenny Tran said that 2mm is about ideal for the oil feed line diameter. However, the DSM feed lines are substantially larger. When I connected a 1/4" oil feed line to the remaining section of stock tubing on my T25 (on a D16Y8), the turbo smoked somewhat under decelleration and low rpm's (odd...), but I know the bearings are in great shape. I tightened down a section of the line in an attempt to reduce the smoke and it did reduce the smoke, but not completely. Now I'm wondering whether to shrink the opening all the way to the 2mm diameter hole that Kenny suggested. My main concern is that this is waayy smaller than the stock feed line diameter and I don't want to burn the bearings. Thoughts? Opinions?
Old May 16, 2003 | 09:09 AM
fsp31's Avatar
Default Re: Oiling issues on DSM turbos... (fsp31)
Anyone?
MotorMouth
Mar 20, 2006 07:12 PM
eg6_lsi
Mar 18, 2004 04:46 PM
delslowh23
Feb 28, 2004 04:59 PM
importboi22
Oct 15, 2003 07:46 PM
rpm9100
Jun 13, 2003 03:55 PM
