oil and spark plug question for turbo
Old Apr 12, 2007 | 07:06 PM
Hazymix's Avatar
Default oil and spark plug question for turbo
What kind of oil should i run and what kind of plugs should i run?? do i run stock plugs or colder plugs or stock plugs and gap them differintl??? i have a ls motor that im boostin within the next couple days???
Old Apr 12, 2007 | 07:11 PM
PrecisionH23a's Avatar
Default Re: oil and spark plug question for turbo (Hazymix)
10w-30
NGK 3330 gapped to .0028"
Old Apr 12, 2007 | 07:27 PM
Hazymix's Avatar
Default Re: oil and spark plug question for turbo (PrecisionH23a)
so how do u noe how to gap the plugs does it matter on the application or how much boost or thats what u gapp the plugs at??? cause a coworker said .0035 but hes itno domestic
Old Apr 12, 2007 | 07:32 PM
Because I tune cars for a living.
You want a smaller gap so the boost does not blow the spark out. Each set-up is different, but I typically use .028" for up to around 12psi. I've gone as tiny as .017" before but there are a lot of factors that can come into play. So to answer your simple question, try .028".
Old Apr 13, 2007 | 04:29 PM
Hazymix's Avatar
thanks bro
KandabashiDevil
Honda Civic (2001 - 2005)
Dec 10, 2011 10:12 AM
R.S.AKIMOTO
Apr 18, 2007 09:56 AM
frankenstienEk
Jan 15, 2007 04:10 PM
TEG777
Oct 3, 2005 04:43 PM
Prelude Vtec 23
May 25, 2002 07:40 PM
