oil sender size...
I did a search and couldn't find anything on the size of the oil sending unit. what kind of socket would I need to get it off. Also, do I need to unplug it before taking it off. If so, how do I unplug, I couldn't really get the rubber boot off of it. thanks again
on a D series it is right above the oil filter, takes a 23 or 24mm socket.. You will then need to buy a 1/8 NPT (pipe thread) brass 3 way T and a 1/8 NPT nipple (i like nipples)
just put it all on there and boost the hell out of her..
Oh yeah use rtv or teflon to seal it.. all else fails JB weld
Jeremy
(edit)....rubber boot...its hard you gotta give it hell and pull it off ..thats about it
[Modified by JSutterEH2, 12:50 AM 9/14/2002]
Jeremy
hatchboy
Mar 19, 2007 03:22 AM
