oil sandwich adapter
Old Sep 21, 2006 | 07:06 AM
aryiman98civic's Avatar
Default oil sandwich adapter
I was wondering what oil sandwich adapter will let me hook up my oil pressure gauge and also my oil feed line so i dont have to put a t fitting in my block? i can't seem to find one that does both. thanks a lot, i have a 98 civic with a b16a2 block in it and i will be going turbo as soon as i get the rest of my parts.
Old Sep 21, 2006 | 07:40 AM
mike1114's Avatar
Default Re: oil sandwich adapter (aryiman98civic)
I got this off egay, it has two 1/8 npt ports (on bottom) so you can run two feeds off of it.
The only thing you would have to do is block off the two -8an holes. I have an oil cooler so it comes off of those.
Old Sep 21, 2006 | 07:49 AM
631 Teggy's Avatar
Default Re: oil sandwich adapter (mike1114)
My Greddy sandwich lets me have both fittings. I've looked at the golden eagle, and that one will do it too.
Matter of fact, I think both Greddy and Golden Eagle have 3 ports.
Old Sep 21, 2006 | 08:15 AM
nuttybumpo's Avatar
Default Re: oil sandwich adapter (631 Teggy)
Is there a sanwich plate adapter type thing that relocates also?
Old Sep 21, 2006 | 08:44 AM
15psi of fun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">My Greddy sandwich lets me have both fittings. I've looked at the golden eagle, and that one will do it too.
Matter of fact, I think both Greddy and Golden Eagle have 3 ports.</TD></TR></TABLE>
Unless they have changed it the golden eagle only has 2 port
Old Sep 21, 2006 | 08:47 AM
20yrsToMidnight's Avatar
Default Re: oil sandwich adapter (15psi of fun)
the tuner toys fitting has 3 outlet ports
Old Sep 21, 2006 | 09:55 AM
riceball777's Avatar
i'm useing the ac autotechnic one which has 4 1/8npt ports
i use all 4 ports
1 for turbo
1 for vtec head
1 for oil temp sender
1 for oil presser sender
Old Sep 21, 2006 | 09:57 AM
so if i find one with 3 ports then i can do my oil pressure gauge and my oil feed?
does there have to be a specific type of port to run the feed line as well?
Old Sep 21, 2006 | 10:18 AM
Default Re: (aryiman98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aryiman98civic &raquo;</TD></TR><TR><TD CLASS="quote">so if i find one with 3 ports then i can do my oil pressure gauge and my oil feed?
does there have to be a specific type of port to run the feed line as well?</TD></TR></TABLE>
1/8th npt normal fittings go on the adapter... 1 for your turbo, 1 for your gauge, 1 for your stock oil pressure sensor..
Old Sep 21, 2006 | 12:03 PM
Crab-Cakes's Avatar
can you just run a t- fitting off the golden eagle one..one for the feed and one for the gauge???
Old Sep 21, 2006 | 12:35 PM
mike1114's Avatar
Default Re: (Crab-Cakes)
crabcakes, yes you can........BUT......
IF you tee oil pressure gauge and turbo feed together, the turbo will for a fact, cause a lower pressure reading than the motor is actually seeing. About 20-30 psi difference!!!!!!!!!!!!!!
I have found this out for fact recently as I thought this was happening so I ran oil feed seperately.
Old Sep 23, 2006 | 06:35 PM
631 Teggy's Avatar
Default Re: (mike1114)
You don't want to T anything with the oil feed.
Even if you get an oil sandwitch with one port, just use that one port for the oil feed, and then pull the stock pressure sensure out of the block, and run a line with a T to the stock sensor, and the pressure sending unit for the guage.
Old Sep 23, 2006 | 07:32 PM
Crab-Cakes's Avatar
Damn that sucks now bc im going to need to get a new sandwich plate that has 2 differnt 1/8th ports on it..what would you guys recommend??
-George
Old Sep 23, 2006 | 08:04 PM
Everyones Hero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">I got this off egay, it has two 1/8 npt ports (on bottom) so you can run two feeds off of it.
I'd take that over my GReddy. GReddy comes in Jap and all the fittings are BSPT, not NPT, which made findng the fittings I needed a pita.
totsie7944
May 1, 2008 04:52 AM
turboH22Aakkord
Apr 12, 2006 10:08 AM
russian_accord
Mar 27, 2005 07:52 AM
mike93eh
Mar 26, 2005 03:01 PM
Muckman
Oct 7, 2003 01:16 PM
