Do you mean the piston oil ring separator? You don't "fit" those. You use the one provided in the ring pack unless you are trying to adjust the oil ring tension. Adjusting oil ring tension is only required in highly specialized engine builds.
yes that is what i am referring to.
All i have is that you put it in the bore and make sure its not overlapping and that the ends are not too tight.
