charger backfire wont idle below 2k
ok so give you a quick run down 96 ek, p28 chrome gold, b20z-v jackson racing charger , sprayed down all gaskets and lines with carbkleen didnt notice change in rpm.. any ideas, i have unpluged the iacv and still runs just low and surges, tps and map when unpluged engine falls on its face. need to get this running before monday morning. one thing i do notice is if someone steps on the ecu conversion it will bog and die... then step on it again and works fine..
Last edited by Street_sleeper; 07-24-2011 at 02:37 PM. Reason: more info about car.
Re: charger backfire wont idle below 2k
so the jumper dosent seem to be the problem but when i wiggle the harness side it just dies instead of smoothing out i dont think this is the problem. (just went out and moved every wire)
