oil ring gap too large???
Old Nov 22, 2008 | 02:08 PM
blackeg's Avatar
Default oil ring gap too large???
got some je proseal rings for my 84.5mm b20 block. ive got the top 2 ring gaps about where i need them, but the thin rings for my oil ring have large gaps. je says no less than .015", but can it be too large?
most of mine are .020-.025", but one of them is huge, around .035". this is all with no filing of course, just right out of the pack. can i use that??? the motor will be daily driven and only make about 200whp
Old Nov 22, 2008 | 02:11 PM
boostedcivicsir's Avatar
Mr. Badwrench
i could be wrong but i have never filed oil rings.
Old Nov 22, 2008 | 03:11 PM
NJIN BUILDR's Avatar
The oil ring gap is not critical.I've run them as much as .060' with no issues.If you have .035" you don't have any problem.
Old Nov 22, 2008 | 03:15 PM
Turbo B18C EJ6's Avatar
yeah i have never heard of filing the rails for the oil control ring before i usually only file the two compression rings. .035 gap seems too large of a gap to me. i know the rule of thumb when building a turbo motor to have the gaps larger for heat compensation but for a n/a build they should be closer to stock. correct me if im wrong.
Old Nov 22, 2008 | 03:17 PM
whoops my bad i didnt read haha i see you are only talking about the oil rings being.035 i guess thats ok
Old Nov 23, 2008 | 06:59 AM
blackeg's Avatar
i know you dont file the oil rings. i just put that in there to help the point of the ring came that large and it wasnt something that i did myself.
the top rings i had to file down. they came out the box at about .013" and i filed them down to get around .017". the 2nd ring i only had to file 1 of them, the others were .022" right out of the box, which is a little larger than i wanted for the use the motor will get, but it is still acceptable imo. none of this woulda happened if rs machine sent me the right rings in the first place, or could at least get me the replacement correct set within a month...
Old Nov 23, 2008 | 08:09 AM
LSVtechnologytur...'s Avatar
rebuilding the hatch already???
Old Nov 23, 2008 | 12:33 PM
blackeg's Avatar
the da is getting a nice new motor. hatch is still going strong 9k+ miles later
RACEPAK
Jul 28, 2013 10:44 AM
blackeg
Apr 1, 2012 12:58 PM
j0keefe21
11
Jun 22, 2009 04:20 PM
jtracing919
Jan 25, 2006 05:06 PM
