Oil Return Hose Heat Wrap
Old Feb 24, 2004 | 07:11 PM
ninja8oi's Avatar
Default Oil Return Hose Heat Wrap
My oil return line sometimes touches the downpipe. Does anybody know if there is some material that I could wrap around it. It's around 1 ft long. I know the drag kit comes with some shiny metal wrap. Where can i get those. thanks.
Old Feb 24, 2004 | 07:13 PM
redboost10's Avatar
Default Re: Oil Return Hose Heat Wrap (ninja8oi)
http://www.summitracing.com, um im not sure what the stuff is called but im sure you could search on there and find it. ill look too
type heat wrap into the search area
Old Feb 25, 2004 | 03:47 AM
BROOD's Avatar
Taylor fire sleeve (comes in orange and silver) is your best bet. You will need to move the drain line off of the DP though, if it is actually touching it your screwed with heat sleeve or without it.
Old Feb 25, 2004 | 04:36 AM
ScrapinSi's Avatar
Default Re: Oil Return Hose Heat Wrap (BROOD)
This is what your looking for
NOTE: 1600x1200 pic
http://www.scrapinsi.com/photo...7.jpg
Made by Earls... My buddy gave it to me... Careful though... Its bigger than the oil return line, and made me not realize that my oil return line had a small kink in it.
Old Feb 25, 2004 | 04:46 AM
mike1114's Avatar
Default Re: Oil Return Hose Heat Wrap (ScrapinSi)
Yea, the Earls Flame Guard or whatever you call it is great. I have it also on my oil return line. You can get it in different diameters but the only one that will fit a -0an oil line is the 1 1/4 one. Maybe the one inch would do it but may be tight.
Old Feb 25, 2004 | 04:50 AM
BROOD's Avatar
Taylor Vertex fire sleeve
Earls flame guard just looks like re-labled Taylor fire sleeve. I'd buy which ever was cheaper, they are probably the exact same material. Good luck
Old Feb 25, 2004 | 05:42 AM
Matt B's Avatar
I use this Thermo-Sleeve it works good.
http://www.alamomotorsports.co....html
hondatuner020
Apr 26, 2011 05:26 PM
ultradx
Nov 14, 2005 08:13 AM
G U E C O
Dec 20, 2003 04:51 PM
C1V1CS1
Oct 16, 2002 12:23 PM
PrecisionH23a
Jun 16, 2002 07:53 PM
