Oil return ..almost done take a look
Old Mar 31, 2003 | 02:46 PM
1bar's Avatar
Default Oil return ..almost done take a look
The install is almost done the only thing i have left is my oil return. I have all earls fittings. Is there a method everyone is using to cutt the stainless line and put the fitting on. Ive been tryin to do it but i end up freying (sp?) the metal. I also tried lubing it up, but no dice.
Another thing my oil filter will not come off lol. im seirous i feel retarded asking but is there an alternative method other then oil wrenches that i can use. My cars oil was changed last at the Dealership. So i dont know if they had someone put it on with an impact gun or something but damn that **** wont come off
[Modified by 1bar, 3:47 PM 3/31/2003]
Old Mar 31, 2003 | 02:55 PM
1bar's Avatar
Default Re: Oil return ..almost done take a look (1bar)
3inch downpipe
Old Mar 31, 2003 | 02:56 PM
SuperT's Avatar
Ah yes, the dreaded fray!
Use duct tape, wrap it about three times very tightly where you are going to cut...
Use either a cut off wheel on your air die grider or a dremel tool with the tiny cut off wheels...
Once cut, unwrap the duct tape so you leave one layer left, sometimes you can get away with completely taking the tap off, sometimes it just flares out on you, so leave on layer on...
Put the fitting in a vise upside down...
Put the hose in(you may have a few strands poking out, take a small screwdriver and poke them back in) Push the hose in, turning as you push on it...push and turn until it bottoms out.
loosen vice,
flip it back up right in the vice...
lube it and take the other end of the fitting and screw it in while pushing up on the hose so it doens't get pushed out...
whoala...
As far as the oil filter,, take a big long screwdriver and a big hammer and pound it through the side of the oil filter and right out the other side and then turn..works like a charm...a bit messy, but works...
Hope that helps ya!
Dave
Super T Motorsports
[Modified by SuperT, 12:00 AM 4/1/2003]
Old Mar 31, 2003 | 02:57 PM
NinjaCivicSi's Avatar
If the line is fraying then try wrapping it in electrical tape or masking tape at the end and then cut it. That should help a little bit.
-Brian
Old Mar 31, 2003 | 02:59 PM
Default Re: Oil return ..almost done take a look (SuperT)
damn, beat me to it
Old Mar 31, 2003 | 03:10 PM
1bar's Avatar
Default Re: Oil return ..almost done take a look (NinjaCivicSi)
damn thanks guys im gonna try that right now
Old Mar 31, 2003 | 03:19 PM
BoostedH23a1's Avatar
yea real pain in the ***
Old Mar 31, 2003 | 05:13 PM
1bar's Avatar
Default Re: Oil return ..almost done take a look (BoostedH23a1)
yeah it sucks
Old Mar 31, 2003 | 05:18 PM
t04s's Avatar
masking tape is the way to go.
Old Mar 31, 2003 | 05:24 PM
johnisenglish's Avatar
Default Re: Oil return ..almost done take a look (evil_rps13)
What I use
But yeah, Steel Braided lines are bitch
Old Mar 31, 2003 | 05:31 PM
inspyral's Avatar
Default Re: Oil return ..almost done take a look (johnisenglish)
masking tape and a dremel work well for me
Old Mar 31, 2003 | 06:21 PM
crx(gator)'s Avatar
Default Re: Oil return ..almost done take a look (inspyral)
what about a pipe cutter? wouldnt that be the easiet thing to use?
Old Mar 31, 2003 | 06:51 PM
shortyz's Avatar
Default Re: Oil return ..almost done take a look (crxgator)
yeah masking tape and a hacksaw works. just dont take the tape off.
Old Mar 31, 2003 | 07:31 PM
Tinker219's Avatar
nope, itll just squish the hose...
JohnnieChimpo
Jan 7, 2009 10:40 PM
myJDM89EF
Jun 9, 2005 08:18 PM
taejin11
Jul 31, 2004 11:47 AM
gloryhog
Jun 20, 2004 11:44 AM
mamaboy
Jan 25, 2004 10:38 PM
