oil restrictor help
Cold start is 80psi.
Turbo is a precision 3431E.
stock b20V.
Been reading around here and there and i just found out that i need an oil restrictor if im at 80 or higher oil pressure. My question is, would these two products fit together and screw into my turbo?
Im guessing THIS restrictor goes into the turbo feed inlet:
http://www.atpturbo.com/mm5/merchant...de=ATP-OIL-022
& this goes on top with the flared part pointing up for my oil feed line correct?
http://www.atpturbo.com/mm5/merchant...Category_Code=
stock b20V.
Did you not even try to read the descriptions? Do you understand how a MALE and FEMALE works? Female has the hole and the male fills it. That is about as much as I want to go into the birds and the bees with you. Your parents should help fill in the rest.
This is what you need. No need for two fittings. This is a 1/8npt to -3 oil restrictor.
http://www.brfittings.com/index.php?...&product_id=91
South Bay Surfer
Jul 10, 2008 10:31 AM
ozzyman
Jul 6, 2005 10:47 PM
