oil pump
Old Jan 2, 2002 | 08:19 PM
88CRXHybrid's Avatar
Default oil pump
Which oil pump should I use for a high hp(500hp) B18B? Type R?
Old Jan 2, 2002 | 10:19 PM
bigTom's Avatar
Default Re: oil pump (88CRXHybrid)
external oil pump...
other than that... just get a pro-drive gear and u should be good
Old Jan 3, 2002 | 09:05 AM
rtype11's Avatar
if you use type R you must also use the R timing belt, just get your B18B with a pro drive gear as mentioned above, If you have a 96 or newer B18B the CFS will not work on the R pump.
Old Jan 3, 2002 | 10:11 AM
Turbo00's Avatar
New User
Default Re: oil pump (rtype11)
i thought timing belts didnt matter for the oil pumps. i just thought if u used a R water pump u had to use the R timing belt
Old Jan 3, 2002 | 10:49 AM
VaporTrail's Avatar
New User
Default Re: oil pump (Turbo00)
don't forget, GSR and Type R use the same water pumps and timing belts also. When you change oil pumps, you don't have to change timing belts.
Fred Demara
Sep 12, 2012 09:18 AM
brad22486
Jan 21, 2012 07:24 AM
dantamparacer
Aug 3, 2009 10:46 AM
01h22lude
Jun 22, 2004 11:17 AM
b20ek
Jun 3, 2003 08:07 AM
