oil pressure switch
hello everybody.
i was wondering how did you all removed your oil pressure switch while you installed your feed line "T"
i changed my oil filter today and i noticed that the oil switch has a hard palstic cover on it... how do i remove it?
is it complicated to screw the "T" into the block? do i need to remove somthing to that will be in my way when ill screw the "T"?
BEST REGARDS
BEST REGARDS
A wrench or socket will work. The black rubber thing is what I think you are talking about and that is the wire connector, just pull it off and take out the switch.
Don’t forget you need a 1/8 BSPT fitting going into the block NOT a 1/8 NPT fitting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">
thank you for the answer.
soo... does the "t" from stan is a 1/8 BSPT ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke »</TD></TR><TR><TD CLASS="quote">A wrench or socket will work. The black rubber thing is what I think you are talking about and that is the wire connector, just pull it off and take out the switch.
Installing it to me was the hardest part about installing a turbo. It is so cramped up there. Plus my car was barely raised on the ground (OEM jack).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 »</TD></TR><TR><TD CLASS="quote">
Installing it to me was the hardest part about installing a turbo. It is so cramped up there. Plus my car was barely raised on the ground (OEM jack).</TD></TR></TABLE>
lol i thought it was the hardest part of the install too lol
to the poster..check out http://www.tunertoys.com they have a fitting made especially for this application. you may want to consider going from their fitting to a T you put on the firewall for easier access and more room. this is what i plan on doing once i get some time to work on it lol
but if you can find a 1/8thbspt to AN you would be better off to get that run a line to a T on the firewall and work from there..supposedly Ts have a tendency to break from the vibrations of the block if you screw them straight to the block.. but i dunno if that really happens better safe than sorry though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 »</TD></TR><TR><TD CLASS="quote">
but if you can find a 1/8thbspt to AN you would be better off to get that run a line to a T on the firewall and work from there..supposedly Ts have a tendency to break from the vibrations of the block if you screw them straight to the block.. but i dunno if that really happens better safe than sorry though</TD></TR></TABLE>
I just switched to oil filter adapter
I just switched to oil filter adapter</TD></TR></TABLE>
i never understaned that.... you can feed the turbo from the filter adapter ?
and what have you done with your oil pressure switch? did you left it on the block?
Modified by RACEPAK at 3:45 PM 4/27/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">
Modified by RACEPAK at 3:45 PM 4/27/2005</TD></TR></TABLE>
I havent installed mine yet, but from what I read on here, yes. The oil goes though the filter and the adapter allows oil to flow to whatever you have connected. The adapter I have has 3 ports. And yes, the oil sending unit would still be connected like it was pre turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">am i gonna need to tourqe the "T" to the block if i'm gonna use some teflon tape?</TD></TR></TABLE>
Not too tight. Yes use teflon tape.
gsr96cx
Dec 23, 2010 07:09 PM
