Oil pressure sensor...slightly different question
Old Aug 2, 2003 | 09:34 PM
TAG's Avatar
TAG
Default Oil pressure sensor...slightly different question
I've searched through all the threads containing "oil pressure sensor" that I could find, but I'm still not clear on something...
This is regarding my 90 CRX Si (ZC blacktop engine).
I'm trying to remove my stock oil pressure sensor from the back of my block so I can connect my oil supply line to my turbo.
So I slide under the car, and I removed the rubber boot that protects the stock oil sensor wire. So far so good.
Here's where I'm confused...
Once I removed the rubber boot, I see TWO wires connected into the block.
I only expected to see 1, not 2 (in all the H-T posts discussing this procedure, everyone says there will only be ONE wire)
These 2 wires both were protected by the rubber boot I took off.
Can someone please tell me what I should do?
My plan was to pull the wire off, remove the 15/16" bolt thing, and connect my oil supply fitting to my turbo. But that 2nd wire is confusing/worrying me.
If it helps any...the 2 wires connect into a green plastic looking circle, which seems to be embedded in the back of the block.
Hope this makes sense. Thanks for ANY help.
Old Aug 2, 2003 | 09:47 PM
sporkcrx's Avatar
Default Re: Oil pressure sensor...slightly different question (TAG)
That's not the oil pressure sensor, that's for the coolant. If you take off your oil filter, you'll see the oil sensor then. It's to the right and above the coolant sensor. Give me a minute and I'll see if I can pull up a pick of mine.
Old Aug 2, 2003 | 09:49 PM
TAG's Avatar
TAG
Default Re: Oil pressure sensor...slightly different question (sporkcrx)
norcalcrx.org member ... to the rescue!
Thanks Sean...I'll slide underneath again right now and see if I can spot it. Thanks for the directions.
Old Aug 2, 2003 | 09:53 PM
sporkcrx's Avatar
Here ya go. See you at the next meet!!!
Old Aug 2, 2003 | 10:58 PM
TAG's Avatar
TAG
AWESOME PIC!!!!!!!!!!!!!
Thanks a million. You saved me LOTS of headache/confusion.
I think this is the most clear pic I have ever seen posted on h-t, haha.
Yoodaman!!!!
Old Aug 2, 2003 | 11:00 PM
civictypenos's Avatar
we just did a crx one today,it was a 27 mm,just for your info.
Old Aug 3, 2003 | 12:12 AM
sporkcrx's Avatar
haha, no problem man. What's the set up?
Old Aug 3, 2003 | 03:54 AM
1dumbscreenname's Avatar
how did you get up there for that good of a shot???
nice pic
Old Aug 3, 2003 | 09:05 AM
bigstatik's Avatar
awesome pic, but.............ew FRAM, heh
Old Aug 3, 2003 | 11:11 AM
LiLOtaku's Avatar
Is the oil from that line already filtered, or post filtered?
Old Aug 3, 2003 | 01:39 PM
sporkcrx's Avatar
Default Re: Oil pressure sensor...slightly different question (LiLOtaku)
It's that good b/c that motor was on a stand when I took that shot. Hell yea, FRAM racing!!! And I've read on here a couple times that that spot is filtered, but I myself have no idea. Only other spot I can think of to run it on a D is the port on the oil pump.
Old Aug 3, 2003 | 04:16 PM
TAG's Avatar
TAG
I figured, either the motor was on a stand when you took that pic, or you drilled a little peephole through your firewall! Haha
Were you asking about MY setup? I didn't know if that Q was directed to me or someone else.
If me, -- it's a turbo zc (greddy kit). Almost done, just need to swap injectors and pop in my charge piping.
Just in time for crxpo (9/13)
Old Aug 4, 2003 | 02:21 AM
sporkcrx's Avatar
Ted w/ the black rex?
Red_ED8
Nov 19, 2007 06:26 AM
KooK
Nov 26, 2005 05:29 PM
MeanGreenEG9
Jan 18, 2004 04:29 PM
SleeprCivic
Jun 20, 2003 10:14 AM
keebler65
Apr 17, 2002 06:47 PM
