Oil Pressure Sensor Placement Q's?
Old Aug 18, 2003 | 11:56 PM
LiLOtaku's Avatar
Default Oil Pressure Sensor Placement Q's?
Just had a quick question.
I was wondering if it is ok to place the oil pressure sensor on one of the ports on an oil distribtuion block adapter(sandwich adapter). Just wondering if the readings will be the same as the ones coming from the stock sensor location.
This is for an aftermarket guage/sensor.
Thanks for any replies
Old Aug 19, 2003 | 12:27 AM
SuperSH's Avatar
Most pressure switches are located right off the filter location anyways. Its one of the closest locations to the oil pump and shows the condition of the pump best.
Old Aug 19, 2003 | 10:28 AM
LiLOtaku's Avatar
Default Re: (SuperSH)
Cool, sounds good mang.
Thanks
Old Aug 19, 2003 | 01:12 PM
sporkcrx's Avatar
Default Re: (LiLOtaku)
I have my sensor on a brass tee, I also have the wire extended but the oil dummy light won't come on. The bulb isn't burned out. Does anyone know what could be causing this?
Old Aug 19, 2003 | 01:48 PM
Nextelbuddy's Avatar
Default Re: (sporkcrx)
um you dont want it to come on when it comes on its most likely too late
Old Aug 19, 2003 | 02:35 PM
here2race-no.b.s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">I have my sensor on a brass tee, I also have the wire extended but the oil dummy light won't come on. The bulb isn't burned out. Does anyone know what could be causing this?</TD></TR></TABLE>
if you ground the wire going to the pressure switch does the light then come on?
Old Aug 19, 2003 | 04:49 PM
sporkcrx's Avatar
Default Re: (here2race-***.s.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">um you dont want it to come on when it comes on its most likely too late</TD></TR></TABLE> <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">ed but the oil dummy light wo</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by here2race-***.s. &raquo;</TD></TR><TR><TD CLASS="quote">
if you ground the wire going to the pressure switch does the light then come on?</TD></TR></TABLE>
I can't believe I didn't think of this. By god you're right you genius! for you! Now, the question is why it's not grounding. Brass tee? Too much teflon on the threads? Good thinkin
Old Aug 20, 2003 | 06:16 AM
I can't believe I didn't think of this. By god you're right you genius! for you! Now, the question is why it's not grounding. Brass tee? Too much teflon on the threads? Good thinkin</TD></TR></TABLE>
Yes too much resistance. Just run a wire to ground and clamp it to the pressure switch (touching the metal part of the switch) and it should work!
Good luck
Charlie
07CRV
Honda CR-V & Element
Sep 30, 2016 04:07 AM
lazlong
Dec 20, 2011 03:48 PM
h22_crx
Jan 19, 2007 03:06 PM
Canuk_SiR
Aug 1, 2002 12:16 PM
