Oil Pressure Sender: How do I remove it?
Old Sep 29, 2001 | 11:07 PM
echo999's Avatar
New User
Default Oil Pressure Sender: How do I remove it?
Ok guys,
I finally had enought time to work on the turbo installation again. question:
I'm trying to remove the Oil pressure sender from the block.. It is surrounded
by a rubber boot, and the tapered end feels like it is flat.
What size wrench do I use (or what tool do I use) to get to this.. and if it's not
a wrench, how do I take this off?
Old Sep 29, 2001 | 11:30 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Oil Pressure Sender: How do I remove it? (echo999)
Ok, first take off the boot and there is one wire terminal that connets to that sensor. Then you need, I think, a 24mm deep wall socket. Im not sure is 24mm but Im pretty sure. Can someone verify this its been a while since I put in my turbo.
art
Old Sep 29, 2001 | 11:33 PM
echo999's Avatar
New User
Default Re: Oil Pressure Sender: How do I remove it? (Arturbo)
Ok, how do I remove that boot?
I tugged on it for like 2 hours, and it's set..
Old Sep 29, 2001 | 11:53 PM
Arturbo's Avatar
Better than steak
25 Year Member
It should just pop off when you tug on it.
art
Old Sep 30, 2001 | 04:53 AM
92CivicSiR's Avatar
New User
Try rolling the rubber lip that wraps around the sender and then pulling the connector off the sender. It should not be that hard.
Novtecdohc
Sep 4, 2005 01:10 PM
ninja8oi
Jan 8, 2004 06:44 PM
TAG
Aug 4, 2003 02:21 AM
BlackB18CTeg
May 14, 2003 05:57 PM
