oil pressure question...Searched
Old Sep 10, 2005 | 05:52 PM
jdkornlp's Avatar
Default oil pressure question...Searched
Just wanted to see if my setup was wrong...I have a b16a2 with 9:1 pistons and before i put the turbo in i was running above 60psi (oil pressure) above 3k rpm and now when i added the turbo feed my gauge is only reading about 40-45 above 3k. I wanted to know if i should relocate my sending unit. Right now i have a feed line comin out of the block to the firewall which is where i mounted the sending unit. From the firewall i have a t-fitting for the turbo feed line also. Is this why my pressure is reading lower?
Old Sep 10, 2005 | 05:57 PM
Still_Good's Avatar
Default Re: oil pressure question...Searched (jdkornlp)
If I'm reading your post correctly, you're saying that you're drawing oil to lubricate your turbo from the same fitting that you use to take oil pressure for your gauge?
If this is the case, then yes, I'd try using a different oil source for either one of the two.
Old Sep 10, 2005 | 06:05 PM
jdkornlp's Avatar
Default Re: oil pressure question...Searched (Still_Good)
yea...its basically a t-fitting off of where the stock oil pressure sensor goes...one for the feed line and one for the gauge...i removed the stock oil pressure sensor
Old Sep 10, 2005 | 06:07 PM
jdkornlp's Avatar
when i installed it i guess i always just assumed the oil pressure would be the same no matter where i put the gauge...but im guessin im wrong?
TravisBiggie
Aug 20, 2013 07:48 PM
hotshot100
Apr 14, 2010 05:10 PM
pip9
Apr 14, 2006 08:29 AM
AzG35
Nov 15, 2004 09:08 PM
slo blue
May 27, 2002 08:30 PM
