oil pan keeps leaking
Old Jul 12, 2004 | 03:14 PM
See Are X's Avatar
Default oil pan keeps leaking
I've changed the oil pan gasket twice, it's still leaking. How much should I torque the nuts/bolts to? I torqued them to 9lbs, but it seems like that's too much, because it's squeezing the gasket out to the side. Also, i think my oil pan is warped, the holes where the bolts go, it's rising up a little. I hate leaks, this is shitty. Any advice?
Old Jul 12, 2004 | 03:53 PM
HXMan's Avatar
Default Re: oil pan keeps leaking (See Are X)
Did you use sealant where you are supposed to?
Did you clean off the old sealant?
Old Jul 12, 2004 | 04:01 PM
specv5150's Avatar
Default Re: oil pan keeps leaking (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">Did you use sealant where you are supposed to?
Did you clean off the old sealant?</TD></TR></TABLE>
I second that. Mine oil pan leaked after my install (except at idle) and it was the gasket. I took it off, applied that RTV crap AND the OEm gasket and it sealed perfectly. No leaks
Old Jul 12, 2004 | 10:28 PM
See Are X's Avatar
Default Re: oil pan keeps leaking (specv5150)
i put RTV on both sides of the gasket. I heard that's not good? I also heard that its better to not use RTV at all? One other thing I just noticed was, that on my stock 2000 b16 oil pan gasket, it has metal rings built inside the gasket where the bolts go. But on the ones I bought from the acura dealer(i bought ITR gaskets) they did not have these metal rings..Whys that?
Old Jul 12, 2004 | 10:43 PM
Blackack26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">i put RTV on both sides of the gasket. I heard that's not good? I also heard that its better to not use RTV at all? One other thing I just noticed was, that on my stock 2000 b16 oil pan gasket, it has metal rings built inside the gasket where the bolts go. But on the ones I bought from the acura dealer(i bought ITR gaskets) they did not have these metal rings..Whys that?</TD></TR></TABLE>
Not sure about the metal rings, mine came with them for my ls. I dont have any leaks and I didnt use any RTV sealant. I just tightened the bolts down in a criss-cross pattern without using a torque wrench. Just made sure the bolts were "snug".
Also, just because it leaks dont go out and buy another gasket, thats a waste of money. The gasket lasts a long time when properly installed and can be reused.(unless its royally fuxored)
Old Jul 12, 2004 | 10:56 PM
djfob's Avatar
Default Re: oil pan keeps leaking (Blackack26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">
This exactly what I did and it worked fine
Old Jul 13, 2004 | 07:32 AM
See Are X's Avatar
Default Re: oil pan keeps leaking (djfob)
i know for a fact that the gasket it busted. I can see some of the gasket coming out of the side, the bolt put a slit in it from the pressure, and is being squeezed out to the side.
4DRmafia
Feb 6, 2007 12:04 AM
StreetRacinThug
Dec 21, 2006 08:44 AM
vegaskurt
Aug 18, 2005 09:30 AM
htownteg
Oct 27, 2003 04:28 PM
AK94GSR
Jun 24, 2003 01:24 PM
