oil lines help t3t4 guys
i have a garrett t3t4b turbine, need 2 oil lines. at amstreetrod.com they sell earl's hoses and fittings. i dont know what size to purchase. [turbo isnt hear with me its at my moms 50 miles away] any t3t4 guys? if you guys bought from amstreetrod.com whatd u buy?
Re: oil lines help t3t4 guys (egMee)
depends on the elbow u use.. i belive the turbo itself is 1/8 pipe thread. then u screw in an adapter to it. 3-4 AN will work fine.
Run a -3 AN line. A -4 may feed the turbo too much oil.
The Garrett center section should have a 1/4" inlet which will require you to get a 1/4" - 1/8" adapter and a 1/8" - -3 an fitting.
