oil line size?
Old Jul 23, 2004 | 12:04 PM
Ad4mGSR's Avatar
Default oil line size?
as of right now i am using an earl -6an line with a 90degree elbow off the turbo, the guy at the speed shop said oil lines are typically -6an's. so i said fine give it to me. my motor is consuming a little oil, but it was before, after all it does have 110k on it. there is no difference in the amount of oil that is being consumed in my motor, i see no oil leaks on the feed or return line, or on the T in the back of the block, but sometimes when i am driving i can smell burning oil. maybe because i have a hole in the hollow cat and im running rich i am mistaking that smell for oil?
heres a pic of the oil line
Old Jul 23, 2004 | 01:15 PM
pollito's Avatar
Default Re: oil line size? (Ad4mGSR)
Check for oil in your charge pipes and in your DP. If you find a lot, it's probably the turbo seals getting too much oil pressure from that rather large feed line.
Dre90
Apr 20, 2010 04:11 PM
South Bay Surfer
Jul 10, 2008 10:31 AM
hackish
May 17, 2004 09:45 AM
revhigh96
Sep 6, 2003 08:19 PM
E Swift
Nov 2, 2002 09:17 AM
