oil light flashes
Old Jul 22, 2013 | 07:12 PM
tepasoelrolo's Avatar
Default oil light flashes
Hello sorry if posting in wrong place but i have a question i have a gsr turbo with arias pistons eagle rods arp headbolts arp rod bolts head ported polished etc precision turbo tuned @12psi dailey driving etc.my oil light was flashing before so i replced oil pump oil pressure switch pick up tube last month and light when off but now when i drive the car its fine till it warms up to specs i stop at a light or stop sign and the ight comes on then when i pull off it starts flashing been doing it for two days now and i just park my car any help please thanks
Old Jul 22, 2013 | 07:34 PM
Turbo-LS's Avatar
Default Re: oil light flashes
You are losing oil pressure somewhere, most likely through a spun or beat up bearing or way to large or a bearing clearence. Drop the pan and check bearings. If you put a new pump and pressure switch and at warm idle your light is coming on your have oil pressure bleed off internal on the motor.
Old Jul 22, 2013 | 07:40 PM
Bearings were installed new from machined shop i should just do them myself which ones should i get for b18c1 with eagle rods and what clarence
Old Jul 22, 2013 | 07:43 PM
Turbo-LS's Avatar
Before you go buying anything, you need to see whats going on.
Old Jul 22, 2013 | 07:50 PM
So u think its my bearings cause i just chsnged my oil pump oil pressure switch pick up tube last month yhats why im looking for some help
Old Jul 22, 2013 | 07:53 PM
Turbo-LS's Avatar
Im trying to give you some ideas but ultimately you need to take the motor out and apart and see what the real issue is. We can't diagnose low oil pressure through a computer screen
Old Jul 22, 2013 | 08:00 PM
Lol yeah i wish il have to tear it apart then damm
Schultzie
Jul 10, 2010 08:58 PM
gloryman_17
Aug 12, 2008 02:59 AM
b.d.racing
Aug 7, 2006 09:54 PM
