oil light on...
Old Jun 18, 2006 | 04:12 PM
acman1's Avatar
Default oil light on...
does this always mean low or no oil pressure? its a built gsr turbo. im looking to buy it from someone on the board, but he said the oil light just came on and now it is smoking a little and there was a ticking noise at 2-3k rpm's. when he took it somewhere, the mechanic just said it needed a valve adjustment. should i be worried? any ways to check to see if its an oil pump or the motor is f'ed? let me know if you need anymore info to diagnose the problem.
Old Jun 18, 2006 | 04:13 PM
A.E Motoring's Avatar
Default Re: oil light on... (acman1)
i would pass on it, dont give your self more problems
Old Jun 18, 2006 | 04:14 PM
BoostedEG6's Avatar
if the oil light is coming on and its ticking then I would STAY away from it!!!! unless you want to replace the motor soon
Old Jun 18, 2006 | 04:18 PM
qfast817's Avatar
Default Re: oil light on... (BoostedEG6)
yea dont buy
Old Jun 18, 2006 | 04:42 PM
TypeSLO's Avatar
Default Re: oil light on... (qfast817)
why are you even asking?? don't buy!
Old Jun 18, 2006 | 06:03 PM
coneheadsracing's Avatar
Default Re: oil light on... (TypeSLO)
Or......... buy it cheap, thats a good barganing chip, if you are mechanicaly inclined.
Old Jun 18, 2006 | 06:07 PM
Joseph Davis's Avatar
Stock Honduh oil pressure switch it a *five* psi switch. If the switch is bad... I've only heard of this happening once, but it is possible... then you could walk with a decent car for pennies if you play it right.
If the oil pressure switch is right, then consider the bottom end and turbo shot, and figure how much it (and the work to fix it) is worth to you then.
19Accord97
Jan 30, 2012 06:25 AM
Schultzie
Jul 10, 2010 08:58 PM
team 15
11
May 24, 2010 12:53 PM
jpeso23
Jun 14, 2008 09:22 AM
tegda
Jan 13, 2007 11:00 AM
