oil leaks suck!
Old Mar 31, 2002 | 06:57 PM
SIK IN DA HED's Avatar
New User
Default oil leaks suck!
well, i just got finished working on my oil line leak on my oil pan. i applied a light coat of JB weld. heard it works better than the weld compound. it seems like it would work better, considering it had better consistency and not so dry and claylike. lets see if it works out... too many oil spots wherever i park.
one opinion i wanna get from you guys, though...
i noticed that im starting to get a noticable headgasket oil leak. i want to prevent any further damage to the engine by either replacing it with an inlinepro headgasket or a blockgaurd. what do you recommend? i know its better to consider getting a new block... its quite costly.
Old Mar 31, 2002 | 07:01 PM
Phantom's Avatar
Default Re: oil leaks suck! (dlplayboy)
I say get a block guard, it sounds like that will solve all your problems.
Old Mar 31, 2002 | 07:10 PM
SiR Kid's Avatar
New User
Default Re: oil leaks suck! (Phantom)
ROFL.
Blockguard fo sho!
That piece of aluminum works wonders for everything that's bad about honda Engines....
Old Mar 31, 2002 | 07:29 PM
Ray's Avatar
Ray
New User
Default Re: oil leaks suck! (SiR Kid)
Blockguard for a headgasket leak???
Remove the head and use some copper spray($6-7 at most auto stores)
Old Mar 31, 2002 | 09:14 PM
TurboInteg95's Avatar
actually forget about any special headgaskets. Just go to the dealer and pick up a new factory headgasket for the car and slap it on. You dont want to lower compression at all, plus the factory one is probably cheaper. Forget about the blockguard.
Old Mar 31, 2002 | 11:05 PM
New User
Default Re: oil leaks suck! (TurboInteg95)
i thought getting a blockguard was a good thing?
Old Apr 1, 2002 | 05:34 AM
rickC1's Avatar
go get beer can and make a gasket whit it
Old Apr 1, 2002 | 06:02 AM
CovertFI's Avatar
Default Re: oil leaks suck! (rickC1)
the block guard prevents the cylinder walls from moving under high pressure, so how is this going to help an oil leak? unless he doesn't have a block guard already and the cylinder walls are some how moving the head gasket around!
Old Apr 1, 2002 | 10:04 AM
New User
Default Re: oil leaks suck! (CovertFI)
actually, a blockguard would be an addition to the new head gasket. just wondering if i should go with an inlinepro or some other brand instead of stock. im just wondering what blockguards are good. got some opinions before... but never really narrowed it down to the best one to get.
Old Apr 1, 2002 | 08:30 PM
Ray's Avatar
Ray
New User
If your gonna get a blockguard, go with STR. Headgasket go with stock or cometic both good and cheap.
Old Apr 1, 2002 | 08:32 PM
Flamenco-T's Avatar
Default Re: oil leaks suck! (Ray)
blockguard goes on top of the cylinder walls, and headasket goes between the head and block
it's two different thing
get a head gasket to solve your leakege
Old Apr 2, 2002 | 06:41 AM
New User
Default Re: oil leaks suck! (Flamenco-T)
yeah, i already knew that. im just wondering what my options are while im at it. since the search option is trippin rite now...
Old Apr 2, 2002 | 06:48 AM
blueciv69's Avatar
What about your head bolts are those stock? how much boost you running? I have had this problem before with two customers, change the gasket and used arp bolts and it never happend again.
Old Apr 2, 2002 | 07:36 AM
New User
Default Re: oil leaks suck! (blueciv69)
only doin about 5-7lbs of boost on my LS motor that has 131,000+ miles on it. still has the stock bolts on em. one thing.. is that the last head stud on the left is broken, so i pretty much have to tap a new stud. shop broke it during the install and i was too anxious to drive my car that i just took it that way.
Old Apr 2, 2002 | 07:42 AM
bQQsted hybrid's Avatar
Welp, I think you found the answer to your problems .
Old Apr 2, 2002 | 07:44 AM
blueciv69's Avatar
Default Re: oil leaks suck! (bQQsted hybrid)
yeah, I say you found your problem. Stock head bolts are<edit> known to stretch with boost making the head gasket vunerable to blow out. Happend to me all the time.
[Modified by blueciv69, 4:46 PM 4/2/2002]
[Modified by blueciv69, 5:53 PM 4/2/2002]
Old Apr 2, 2002 | 08:49 AM
New User
yeah, I say you found your problem. Stock head bolts are know to stretch with boost making the head gasket vunerable to blow out. Happend to me all the time.
hmmm thats interesting. i didnt know that would happen. dumb *** at the shop said i shouldnt have a problem. i tried to have them repair it a few weeks later but they kept givin me excuses. oh well... too late now. the shop closed down.
i figured the headgasket was gonna go anyway. i boost the shiznit out of it and i have 131,000+ miles on my motor. i expected it to happen sometime. ive been boostin hard for 1year and a few months now... time to start upgrading things.
thanks for the info, guys.
diyguy13
Mar 12, 2009 05:55 AM
turbotime
Dec 22, 2005 01:46 PM
GruvyTune
Oct 24, 2003 04:05 PM
GruvyTune
Oct 16, 2003 09:20 PM
DC2R714
Jul 19, 2002 05:25 AM
