OIL LEAKING FROM TURBO ????????
The pipe that goes to where the red arrow is pointing blew off today in the highway when i went to put it back on I Noticed there was oil in this pipe is there supposed to be oil in the pipe ????? someone told me that an oil catch would fix this problem is this true ????? if not what could be wrong ???? Could it be that the actual turbo is fucked up the seal or something............... And how is oil getting there to begin with if is not the actual turbo leaking ................
so my turbo is fuked.... theres is nothing else it could be how do i fix the seals in the turbo
Modified by GdmBlk99SI at 9:31 AM 6/24/2006
If you pass your finger by it.. your finger come out oilly and you can see the oil in finger and like a drop on the inside of the copling....
Thx is this going to be fine or not... Do I Need new Turbo??
Will the oil catch can help this situation???
I would guess that you need to look inside your intake plumbing as well. If you have a PCV or valvecover nipple plugged into your intake piping, the turbo will create a huge vacuum and suck oil right of the head of your engine and send it on its way to the combustion chamber. Thats how a catch can would help you, by seperating the oil vapor out of the air that goes through the PCV and valvecover.
So in other words if between your air filter and the turbo inlet you have a hose connected to the engine, the turbo is probably sucking oil vapor. But if you don't have it setup that way, then yes, the oil would have to come from the turbo itself.
sonne_side
Mar 31, 2009 11:40 PM
time for rebuild
