Oil Gauge
Old Oct 10, 2001 | 06:28 AM
whagkangmakulet's Avatar
Default Oil Gauge
I recently added an Autometer Oil Gauge (100psi range) It was working great for 3 days ..then it suddenly stop working!! I didn't have enough time to take my cluster off again..but i check my connection on the sender unit and everything is intact! could a pressures more than 100psi mess everything up? any advice before i take my cluste off ( i have my gauge on the dashboard panel..very hard to take off) pls help!!!!
Old Oct 10, 2001 | 07:39 AM
rtype11's Avatar
Default Re: Oil Gauge (whagkangmakulet)
dude check your engine oil, my friend had the compression fitting on his gage break and after a week his motor was dry but his interior was soaked with oil.
Old Oct 10, 2001 | 09:09 AM
98ITR#0020's Avatar
definately try to find time to take the cluster off, or you could end up with a serious mess, or worse...
Old Oct 10, 2001 | 10:13 AM
Default Re: Oil Gauge (98ITR#0020)
I EMAILED AUTOMETER!!! they suggested to test the sender unit (electronic gauge version) with an ohmmeter... they said i could have damage it by over pressure or sort of vibration issue!!! i'll test it tonight!! i'll let you guys know!!!! at what PSI are your meter range to?
Old Oct 10, 2001 | 11:29 AM
DirtyLude's Avatar
How is the sender connected? Remember that the sender needs to be grounded so if it's connected using a hose (even a steel braided one) it may not be grounded and may not work. I had this problem putting one in a friends car using steel braided line. I had to attach a ground wire to the sender itself.
Old Oct 10, 2001 | 01:03 PM
98ITR#0020's Avatar
I have the mechanical one, but it reads around 20psi at idle
Old Oct 10, 2001 | 01:51 PM
Default Re: Oil Gauge (DirtyLude)
it was working for three days though... i have a T connected on my block...But i'll check it out..thanks... under boost what is the maximum psi reading do you guys have?
Old Oct 10, 2001 | 02:07 PM
SiRkid's Avatar
T connected to block=bad!! http://www.theoldone.com/articles/oilpressure/
Old Oct 10, 2001 | 04:26 PM
wwcivic's Avatar
New User
Default Re: Oil Gauge (SiRkid)
Has anyone here tried to hook up the T like T.O.O says? I did and guess what ... it sucked ... oil pressure light came on if rpm's dropped below 900. So I put the T on the block, problem solved. It sounded like a good idea at first, but just gave me additional problems. Besides, I doubt that nylon tubing would have held up anyway.
Old Oct 10, 2001 | 04:31 PM
turbod97ex's Avatar
New User
Yeah, I looked into this setup too. The supercharger, that ENDYN uses, creates more vibration than the turbo setups, and, the supercharger doesn't get cooled by the engine oil as in most turbo'd applications. If you do go the route that is on TOO, make sure you make the strain releif hose, which on their site is 1/8", at least double in size to 1/4" or even more.
Old Oct 11, 2001 | 11:56 AM
Default Re: Oil Gauge (turbod97ex)
OK GOT MY OIL PIPING TODAY... I'LL put them on today!!! I bought a steel braided version. I think it's a good idea of the endyne! Thanks for the link...it's better than 'T' that's my opinion? 1. it will hit my oil filter(long version of oil filter. 2. it's better to the sender unit, autometer said that vibration could cause the sender to break(i have the motor mount insert.. vibrating is problem). what do you guys use anyway? same setup? I believe that not getting enough pressure on the turbo is not a concern ..due to psi requirement is only 30-40 psi on the turbo. and it's about 75-100 under boost. thanks for the help guys!!!!
[Modified by whagkangmakulet, 9:00 PM 10/11/2001]
Old Oct 11, 2001 | 12:18 PM
SiRkid's Avatar
why?
I did it this way and everythign is FINE and DANDY!
my motor is stock though.
i have pics somewhere.
Old Oct 11, 2001 | 12:42 PM
Doodoo's Avatar
Default Re: Oil Gauge (wwcivic)
I did mine the TOO way with steel braided. I have not had a problem yet. Its almost been a year. I have a pic some where, I think I used 1' of line to make sure it had enough slack.
Old Oct 11, 2001 | 01:38 PM
b18b98's Avatar
Default Re: Oil Gauge (Doodoo)
just imagine there's a T fitting at the end.
[Modified by b18b98, 5:40 PM 10/11/2001]
Old Oct 11, 2001 | 03:07 PM
turbod97ex's Avatar
New User
Default Re: Oil Gauge (b18b98)
[QUOTE]just imagine there's a T fitting at the end.
That is NOT what is on TOO. That setup is AWESOME. No measly 1/8" nylon tubing.
BTW, the amount of pressure that the line will hold needs is important, but the VOLUME that the line will carry is equally as important.
Old Oct 11, 2001 | 03:46 PM
SiRkid's Avatar
steel braided is what i looked for....COULD NOT GET IT ANYWHERE...well a plumbing store had it but it was never open on the weekends so I used Brake LINE!
working great so far.
pcguy760
Jul 2, 2006 10:17 AM
95LStizzy
Mar 12, 2006 12:35 PM
Turbo_TONY
Mar 8, 2006 07:46 PM
Blaze45
Dec 6, 2003 08:40 AM
