oil fitting on the back of the block??
Old Nov 6, 2002 | 03:18 PM
Cramerox's Avatar
Default oil fitting on the back of the block for civics???
I did a search but came up with only integras.
Can anyone tell me the size of the fitting and taps into the back of the block for the oil feed? My friends car is a SOHC civic dx.
Thread type would also be nice?
[Modified by Cramerox, 4:22 PM 11/6/2002]
Old Nov 6, 2002 | 03:21 PM
Cramerox's Avatar
Default Re: oil fitting on the back of the block?? (Cramerox)
Feed:
1/8 nipple for block -- 991101
1/8 "T" -- 991701
1/8 to -4AN -- 981604
(2 needed) -4AN straight swivelseal hose ends -- 300104
(4 ft needed) -4AN ss hose -- 400040
For adapter to turbo you will need one of these depending on the size of the hole on the turbo itself.....
1/8 npt hole 982204 (Smaller T3's use this one I believe)
1/4 npt hole 982244 (This was the one I used for my t3t4)
Return:
Aluminum return flange found at turbocharged.com p/n is 20259.
-10AN flange side male to hose -- 824510
(2 ft needed) -10AN hose -- 400100
-10AN 45 to pan fitting -- 804610
-10AN union for tapping pan -- 981510
-10AN bluhead nut for union in pan -- 992410
Stratoseal for union (package includes 2) -- 178014
got this from 93lsivic but still confussed about the fitting...
Old Nov 6, 2002 | 04:08 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
well i dont feel like readin all that crap, but all i know is for the oil fitting tap that i used to run to my oil pressure guage, i used a 1/8th to 3an fitting
Old Nov 6, 2002 | 05:37 PM
Cramerox's Avatar
Default Re: oil fitting on the back of the block?? (SIXTYdashONE)
can anyones else comment?
Old Nov 6, 2002 | 05:47 PM
Farnsrocket's Avatar
I believe it's actually 1/8" BSPT, but 1/8" NPT will work........it has for me.
huge230
Nov 3, 2007 09:58 AM
Mr HYDE
Jul 9, 2005 05:04 PM
redboost10
Dec 9, 2003 01:15 AM
Superorb
Nov 30, 2002 01:08 PM
