Oil feed line restrictors...who has them?
Old 03-13-2002, 03:04 AM
DSF
DSF's Avatar
Default Oil feed line restrictors...who has them?
Anyone know where I could get 2 of them?
Old 03-13-2002, 10:14 AM
HXMan's Avatar
Default Re: Oil feed line restrictors...who has them? (DSF)
Old 03-13-2002, 10:16 AM
D-SPEED's Avatar
Default Re: Oil feed line restrictors...who has them? (HXMan)
i think majestic turbo has them
Old 03-13-2002, 10:47 AM
Ray
New User
Ray's Avatar
Default Re: Oil feed line restrictors...who has them? (D-SPEED)
Autometer #3277
1/8npt-4an fuel restrictor
*might need to bore out slightly*
Old 03-13-2002, 10:52 AM
DSF
DSF's Avatar
Default Re: Oil feed line restrictors...who has them? (Ray)
Thank you!
Old 03-13-2002, 02:47 PM
simike's Avatar
What does an oil feed line restrictor do for you?
Old 03-13-2002, 02:50 PM
New User
TurboSedan's Avatar
Default Re: Oil feed line restrictors...who has them? (simike)
It reduces the oil pressure in the line, so that the turbo will have less of a chance of blowing the oil seals.
Old 03-13-2002, 03:57 PM
simike's Avatar
Default Re: Oil feed line restrictors...who has them? (97CivicFerio)
So if you go to small you can starve the turbo of oil?
Old 03-13-2002, 05:49 PM
Dee
Dee's Avatar
Actually it reduces the flow volume and not pressure. Sometimes when an unrestricted inlet is used the center housing will overfill because it is filling faster than it is draining. The pressurized oil usually seeps past the GOOD oil seals and into the exhaust/compressor because the oil seals are weakest link inside of the center housing. Overfilling is a flow volume associated problem.
Old 03-13-2002, 06:23 PM
Smashback's Avatar
Default Re: Oil feed line restrictors...who has them? (drealgsr)
And it's the problem I have.......which begs the question, is it better/easier/cheaper to get a restrictor or change from -4 to -3 on the feed line?
And BTW think I figured something out the other day. It only does it when the engine is cold and I run 5W30 just like Honda says to on my oil filler cap! I am going to try 10W30 this coming oil change to see if there is any difference...
[Modified by mplex2000, 3:25 AM 3/14/2002]
Old 03-13-2002, 07:22 PM
maxim's Avatar
Default Re: Oil feed line restrictors...who has them? (mplex2000)
That is the exact problem I am facing right now too. Ol is not draining fast enough so its building up and gong through the seals. I mean, I even have oil shooting out of my BOV. No blue smoke yet or rough idle...thank God!!
How many people use those things, I have never heard of it until lately for our turbo charged Hondas?
Old 03-13-2002, 07:30 PM
maxim's Avatar
Default Re: Oil feed line restrictors...who has them? (maxim)
Here, I found a pcture of one just on case you guys were curious before purchasing. BTW, it is referred to as a nitrous/fuel restrictor.
The part # a http://www.summitracing.com is ATM-3277
Old 03-13-2002, 07:55 PM
Dee
Dee's Avatar
that nitrous port is too small! I'll check the size of the restrictor on my extra turbo tonight.
Old 03-13-2002, 08:18 PM
SlowB16's Avatar
So is it a better idea to go with the -3 instead of 4 on a t3t4 b16?? Im about to order my line, just wondering which is better....If I get the 3 is there a chance the turbo wont get enough oil??
Old 03-13-2002, 09:04 PM
D-SPEED's Avatar
Default Re: Oil feed line restrictors...who has them? (SlowB16)
you could drill that thing out
Old 03-13-2002, 09:53 PM
Dee
Dee's Avatar
definitely drill it out because you would only be getting a trickle of oil.
Here's a pic of the one that I use.
Old 03-13-2002, 10:49 PM
New User
Xerxes's Avatar
My oil feed setup (greddy kit) basically has a -3 line going from the block to a set of tees with my oil pressure & temp sensors, and then going to the turbo through a rather large greddy-supplied line (not sure what the size is)
Originally I had the tees directly on the block;
with the tees on the block, my oil pressure gauge showed 75psi when driving around, now with the -3 line (about 20" of -3 between the block and the tees), i see 50psi of pressure. I would imagine that a -3 line the whole way would give you 40-50 psi of pressure at the turbo...
-Xerxes
Old 03-14-2002, 04:16 AM
maxim's Avatar
[QUOTE]definitely drill it out because you would only be getting a trickle of oil.
I might have a problem with oil coming up the threads of the fittng with a restrictor in that position. Wouldn't it be better to have the restrictor coming off the tee from the block? Or is the general consensus to just get a -3 line?
Anybody know what size line comes with the Drag Gen III kit?
Old 03-14-2002, 04:56 AM
DSF
DSF's Avatar
I would put the restrictor as far downstream as possible. If you put it at the block, it's going to restrict flow through the entire feed line, possibly causing extra time to fill the line AND the bearing housing. I'd rather fill the line as fast as possible and restrict flow just to the housing. Theory of course.
Oh, and my DRAG line is -4AN.
Old 03-14-2002, 06:20 AM
blowncivichb's Avatar
drealgsr:
What size hole is that? How did you know which size hole to use?
Old 03-14-2002, 07:05 AM
Default Re: Oil feed line restrictors...who has them? (blowncivichb)
BTW...Good topic!
Old 03-14-2002, 10:40 AM
sgT
sgT's Avatar
The hole in the restrictor that dreal posted looks close to -3
Old 03-14-2002, 01:02 PM
Default Re: Oil feed line restrictors...who has them? (sgT)
When you say -3, do you mean the ID of a -3AN fitting?
Old 03-14-2002, 01:45 PM
Dee
Dee's Avatar
sorry guys but I forgot to measure the restrictor! Work, school and teaching english everyday is kicking my ***! I'll make sure that I do it tonight before getting tanked!
Dee
Old 03-14-2002, 02:55 PM
sgT
sgT's Avatar
Lets think about that for just a second. what would be the point of comparing it
to the OD of a -3 fitting/line??
Quick Reply: Oil feed line restrictors...who has them?
