oil feed line
T off of the stock oil pressure sensor... Or do what I did and eliminate the stock oil pressure sensor and use a T with one end going to the turbo and the other going to the oil pressure gauge. The stock sensor is in the back of the motor by the oil filter... should be to the left (it was on my teg) You should see a sensor with one wire comming out of it (atleast mine only had one wire) but atleast you get the idea. Hope that helps
it's there... you gotta buy an adapter... one side is BST and the other is NPT (don't remember if the acryonms are correct) but yea.. you need an adapter... for the safest route.. run a SS line to your firewall.. at the fire wall get a "T" and one end of the T will connect to your SS line from the block, another end will connect to your oil sensor and finally the last end will connect to your oil feed line... oil feed line will go to the turbo
i'm not sure if you need another adapter to connect your oil sensor to the "T"... i haven't done it in 3 years... but yea.. that's all there is to it
