oil drain....this aint going to work is it?
Old Sep 16, 2007 | 03:23 PM
hotrod99's Avatar
Default oil drain....this aint going to work is it?
Old Sep 16, 2007 | 03:27 PM
Boner_Ben's Avatar
Default Re: oil drain....this aint going to work is it? (hotrod99)
No. Use 2 45's and shorten the line and you got yourself a nice return line.
Old Sep 16, 2007 | 03:41 PM
hotrod99's Avatar
Default Re: oil drain....this aint going to work is it? (Boner_Ben)
thank you,thats what i was thinking but i just wanted someone else's opinion
Old Sep 16, 2007 | 04:01 PM
Tippyman's Avatar
Why does this not work, yet every sink drain in the world has a massive loop in it,
Old Sep 16, 2007 | 04:41 PM
Eddiebx's Avatar
Default Re: oil drain....this aint going to work is it? (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Why does this not work, yet every sink drain in the world has a massive loop in it,</TD></TR></TABLE>
the p-trap on a sink is there to prevent backup of sewer gases by keeping a bit of standing water in the p trap which creates a seal to prevent the gas from coming in. i dont konw anything about turbos, but i woudl imagine one wouldn't want to have any resistance in the oil return line?
Old Sep 16, 2007 | 04:43 PM
boostedcivicsir's Avatar
Mr. Badwrench
in theory it will work, do sinks have seals on the shafts that leak if it backs up?
come on WE ALL KNOW the best turbo drain is a straight shot.
Old Sep 16, 2007 | 05:50 PM
slowteg90's Avatar
Default Re: oil drain....this aint going to work is it? (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
the p-trap on a sink is there to prevent backup of sewer gases by keeping a bit of standing water in the p trap which creates a seal to prevent the gas from coming in. i dont konw anything about turbos, but i woudl imagine one wouldn't want to have any resistance in the oil return line?</TD></TR></TABLE>
lmao, ok plumber guy, go back to home-depot-tech.com....
Old Sep 16, 2007 | 05:52 PM
RC000E's Avatar
Default Re: oil drain....this aint going to work is it? (slowteg90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowteg90 &raquo;</TD></TR><TR><TD CLASS="quote">
lmao, ok plumber guy, go back to home-depot-tech.com....</TD></TR></TABLE>
Sounds like he was watching Modern Marvels when I was....lol.
Old Sep 16, 2007 | 05:57 PM
Tippyman's Avatar
Default Re: oil drain....this aint going to work is it? (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">
Sounds like he was watching Modern Marvels when I was....lol.</TD></TR></TABLE>
I wouldn't want to do it, I was just wondering if there was some reason why it won't work. Like a scientific principle, lol.
Old Sep 16, 2007 | 07:11 PM
Garage 808 Hatch's Avatar
its a damn valid point, and yes, i am a plumber
Old Sep 16, 2007 | 07:47 PM
nikolai.'s Avatar
As long as the turbo drain is the highest point in the system, I don't think there's any reason why it wouldn't work...unless the flow out of the turbo is too high for the size line being used. I also agree that you will have standing oil in the line and a straight line will flow better.
Old Sep 16, 2007 | 09:09 PM
building boost's Avatar
cut the line a few inches so it's not so curvy and you can probably get away with using those fittings.
Old Sep 16, 2007 | 09:23 PM
90dxhmt's Avatar
Oil is thick and does not move flow that great so it needs a nice straight downhill run to make sure it keeps moving.
Old Sep 16, 2007 | 10:03 PM
mike93eh2's Avatar
i would get a 90 on the pan and point it towards the turbo and get a 45 for the turbo.
Old Sep 16, 2007 | 11:19 PM
JaredKaragen's Avatar
shorten that hose and you should be ok.
Old Sep 17, 2007 | 05:05 AM
stockb18c's Avatar
how about you downpipe which way is it goin
Old Sep 17, 2007 | 10:23 AM
hotrod99's Avatar
Default Re: (stockb18c)
heres 2 pics of the hose turned the other way and the downpipe bolted on
Old Sep 17, 2007 | 10:45 AM
Mr. Badwrench
Default Re: (hotrod99)
thats how i did it on my old drag kit. it is ok like that.
Old Sep 17, 2007 | 11:06 AM
hotrod99's Avatar
Default Re: (boostedcivicsir)
well I went ahead and bought a 90degree fitting to see if i can make it any better
Old Sep 17, 2007 | 02:20 PM
Quad-Damage's Avatar
can u run the line behind the downpipe and shorten it and turn the fitting a bit for more of a downward bend
Old Sep 17, 2007 | 02:40 PM
integraRS-T's Avatar
u got a litlle loop but i think it should work
Old Sep 17, 2007 | 04:30 PM
EASY101's Avatar
* B A N N E D *
Default Re: oil drain....this aint going to work is it? (Garage 808 Hatch)
good, i dropped a couple of kids off at the pool who came back for air.
oh by the way, the water wont stop runnin...can you fix that?
j/k
Old Sep 17, 2007 | 04:59 PM
slowteg90's Avatar
Default Re: oil drain....this aint going to work is it? (EASY101)
^ yeh i think we covered that awhile ago.... nice try tho
Old Sep 17, 2007 | 05:41 PM
blackeg's Avatar
i had an old setup like that. i wound up going between the block and the downpipe. the line was like 1/2 inch off the dp so i heat wrapped it. get a 90* and come right up out of the oil pan with it
Old Sep 18, 2007 | 03:23 AM
Topdawgg's Avatar
dang that turbo sits some far over...
too bad you cant flip it around...
I wouldnt run that oil return like that, thats for sure..
