Oil cooler
Old Nov 4, 2002 | 10:15 PM
  #26
JT's Avatar
JT
Default Re: Oil cooler (Speed PHreak)
The B&M kit is not the best quality. I bought one and prompty returned it. I later put together my own kit and fabricated some custom brackets for the cooler. The cooler mounts directly to the frame, and there's enough clearance for a dual core radiator.
Old Nov 4, 2002 | 10:17 PM
  #27
accordfreak's Avatar
Default Re: Oil cooler (JT)
where do you get the adapter for the oil filter???
Old Nov 4, 2002 | 10:26 PM
  #28
JT's Avatar
JT
Default Re: Oil cooler (accordfreak)
I got all the oil cooler components from http://www.racerpartswholesale.com . Just search for "mocal" for the adapter.
Old Nov 5, 2002 | 08:32 AM
  #29
Speed PHreak's Avatar
I got my parts from racerwholesale also. Good guys! They were out of the one adapter plate I ordered They promptly called me and let me know, so we could work out something else.
Old Nov 5, 2002 | 08:41 AM
  #30
Boostless97Lude
Guest
Posts: n/a
what kind of actual oil cooler is that.... i can probably get some of that stuff from one of the local circle track parts dealers around me...
Old Nov 5, 2002 | 09:40 AM
  #31
JT's Avatar
JT
Default Re: Oil cooler (Boosted97Lude)
The cooler itself is being sold as "Tru Cool" from RacerPartsWholesale, but it sure looks like the same ones from B&M. I got the 24 rows version for $44.95.
[Modified by JT, 10:41 AM 11/5/2002]
Old Nov 5, 2002 | 09:49 AM
  #32
Boostless97Lude
Guest
Posts: n/a
since i have a Lude, i was aondering how the adapter would work on any of them, since i've already got a liquid cooler at the filter
[Modified by Boosted97Lude, 1:50 PM 11/5/2002]
Old Nov 5, 2002 | 11:10 AM
  #33
SiRkid's Avatar
my cooler is like yours
so i guess it will work out fine then ..
Old Nov 5, 2002 | 11:53 AM
  #34
technine's Avatar
JT, where did you get the adapter for the oil filter? What size/thread is needed for the D series engines? Specifically the d16a6 because I have the lines and an oil cooler, but not the adapter. Can't find one anywhere.
Old Nov 5, 2002 | 12:48 PM
  #35
AVATAR's Avatar
JT, looks very nice Could you do a break down on the parts needed and rough price for everything? Thanks
Old Nov 5, 2002 | 02:40 PM
  #36
JT's Avatar
JT
Default Re: Oil cooler (AVATAR)
Technine, I got the adapter from http://www.racerpartswholesale.com . I believe the size is 20mm, but please call and verify.
AVATAR, here are the pricing for my cooler setup. It's not cheap. Makes you just want to go out and buy a Greddy kit instead... HTH.
2x 90 degree AN-8 swivel Aeroquip hose end $16.43 ea (for oil cooler)
2x 120 degree AN-8 swivel Aeroquip hose end $25.43 ea (for oil adapter)
1x 24 rows cooler $44.95
1x thermostat oil adapter plate $79.99
12x AN-8 Aeroquip SS hose $4.52 per ft (I bought extra just in case)
4x AN flare fittings $ ??? (can't remember the price)
1x Brass T-fitting $??? (I use this to mount a oil temp sensor)
Old Nov 5, 2002 | 02:48 PM
  #37
JT's Avatar
JT
Here is another pic of the cooler that shows the T-fitting for the temp sensor. It's not the best location for the temp sensor, as it doesn't measure the oil temp in the engine. However, at least I know the temp at the cooler.
Old Nov 5, 2002 | 03:17 PM
  #38
Boostless97Lude
Guest
Posts: n/a
just wondering, but is that JRSC i spy????
also, which kind of adapter is that?
[Modified by Boosted97Lude, 7:19 PM 11/5/2002]
Old Nov 5, 2002 | 03:19 PM
  #39
JT's Avatar
JT
Yes, it's a JRSC. The adapter plate is a Mocal unit which opens at 180 degrees F.
[Modified by JT, 6:27 PM 11/5/2002]
Old Nov 5, 2002 | 03:53 PM
  #40
TheShocker's Avatar
Default Re: Oil cooler (justagsr)
I have a setrab oil cooler with earl fittings. I'm not running it yet but when I get everything back together we will see.
I've heard good things about those. http://www.bakerprecision.com/setrab.htm
-Seth
Old Nov 5, 2002 | 04:00 PM
  #41
BoostedH23a1's Avatar
Default Re: Oil cooler (TheShocker)
what did u pay for it with all the braided stainless steel lines? thats the expensive part..
Old Nov 5, 2002 | 04:36 PM
  #42
AVATAR's Avatar
Well thats roughly $263 w/o the AN flare fittings, so it's still cheaper than the Greddy if it is $400. appreiate it.
Old Nov 5, 2002 | 05:28 PM
  #43
SiRkid's Avatar
you can get those adapters for like $25 from somewhere.i cant find the page..ill try to find it.
Old Jul 21, 2003 | 01:32 PM
  #44
luckypon7's Avatar
is the threading on the adaptor the same as on the block, to where i can use the same oil filter for my 98 gsr?
  #45
luckypon7's Avatar
is the threading on the adaptor the same as on the block, to where i can use the same oil filter for my 98 gsr?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JT &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it's a JRSC. The adapter plate is a Mocal unit which opens at 180 degrees F.
[Modified by JT, 6:27 PM 11/5/2002]</TD></TR></TABLE>
Old Jul 21, 2003 | 01:54 PM
  #46
twkdCD595's Avatar
I am going to be running a earls performance cooler.
http://www.earls.co.uk/
Old Jul 21, 2003 | 02:31 PM
  #47
hatchback19's Avatar
Default Re: Oil cooler (twkdCD595)
i saw some nice oil cooler on ebay
do a search for a mg oil cooler
Old Jul 21, 2003 | 04:28 PM
  #48
JT's Avatar
JT
Default Re: Oil cooler (luckypon7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luckypon7 &raquo;</TD></TR><TR><TD CLASS="quote">
is the threading on the adaptor the same as on the block, to where i can use the same oil filter for my 98 gsr?</TD></TR></TABLE>
Yes, the thread is the same on the adapter as the block. I use the same Honda oil filter.
Old Jul 22, 2003 | 05:46 AM
  #49
89dxhunchback's Avatar
call me getto, but I'm thinking a 5-$10 cooler from a volvo/audi etc would do the trick for me with rubber hoses... $25 total.... Better than nothing....
Not sure an oil cooler would be worth the oil presure drop though... Coolers are just like intercoolers, they have effency, and cause some presure loss.
BTW I was thinking about just putting it between the oil feed line from the block to the turbo.
Old Jul 22, 2003 | 06:01 AM
  #50
Swift's Avatar
Default Re: Oil cooler (89dxhunchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89dxhunchback &raquo;</TD></TR><TR><TD CLASS="quote">BTW I was thinking about just putting it between the oil feed line from the block to the turbo. </TD></TR></TABLE>
yea, that is what I was thinking of doing. But part of me thinks this is not such a good idea since the oilcooler has larger lines than the turbo feed. Can some one whed some light on this?
