which oil catch ?
Old Feb 2, 2011 | 09:17 AM
Nick_p's Avatar
Default which oil catch ?
Hello guys.
which oil catch do you prefered??
i have a cheap from ebay but this oil catch never catch the oil.
i have a light white smoke at idle from the air drain at the bottom of the engine , with or without the oil catch...
i have a B16A2 engine turbo with 9100 rpm limit.
Old Feb 2, 2011 | 12:57 PM
ryguy2588's Avatar
Default Re: which oil catch ?
A lot of people I know use Moroso catch cans. Make sure the one you get one that has breather too. White smoke most of the time means burning coolant.
Old Feb 2, 2011 | 12:59 PM
mr.speaker's Avatar
I've got a moroso with a barb on the bottom that drains back into the block. It was good for 700hp. Before I added the drain I did have problems with it puking oil out of the breather.
Old Feb 2, 2011 | 01:53 PM
Nick_p's Avatar
coolant?? hmm i think i wrote it wrong before.
a light white smoke on the top of the engine...from the air drain ( i dont know the right word for that) and not from the exhaust...sorry..
hmmm i think mine is bit small for 450 hp..so we want a oil catch with breather filter on the bottom..
what about this http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
or this bi one http://cgi.ebay.com/ebaymotors/2-LIT...item3cb3baef41
Old Feb 5, 2011 | 05:06 AM
rwlsvtec_03's Avatar
You can buy them from B&R fittings right here on Honda-Tech. I just bought mine and installed. I got the smaller catch can return back kit for $290 but you can get a one gallon w/3 filters or black braided lines instead of stainless or black can, either way it comes with everything and fits perfect.
Old Feb 6, 2011 | 05:45 AM
EsotericImage's Avatar
Retired Moderator
summit has a catch thats a moroso knock off for 32.00. I think you need to check your routing if its not catching anything..
The valve cover fitting has a breather filter on it. Air flows through the crankcase and out of the PCV port which now has a plastic 90* barbed fitting in it (no PCV valve). From the PCV port, the air flows into the side of the catch can and out of the top of the can. Air then flows back to the pre-turbo intake pipe. A 90* fitting is not required here because air flowing across the opening of the fitting in the intake pipe will draw air out in the direction of air flow (the same reason water comes out the top of a straw when it is submerged in a glass of water and you blow across the top of it).
This routing is not a closed circuit system with the only drive for the system being provided by vacuum.
Thanks to xenocron from G2IC for this PCV plumbing option.
Old Feb 6, 2011 | 12:16 PM
racebum's Avatar
understand the theory with why this works, just wondering if you go this way because it's more effective using the intake tube over the vac port on the manifold or?
Old Feb 6, 2011 | 12:17 PM
racebum's Avatar
Old Feb 7, 2011 | 05:39 AM
xenocron's Avatar
Under boost, you wouldnt be sucking any crank case pressure out...you would be blocking it in.
Old Feb 7, 2011 | 06:56 AM
boosted.si04's Avatar
Go to ALL IN fabrications he makes them custom for your setup and they r legit as sh*t!!!!
Old Feb 7, 2011 | 10:35 PM
racebum's Avatar
so i'm looking at this but don't really grasp how it would be more effective since the valve cover has a breather on it. doing the above would provide some vacuum on the black box but how much and how much better if at all would it perform over a standard baffled vented catch can that you just plumb the vc and black box to?
Old Feb 8, 2011 | 04:13 PM
sohctodohc's Avatar
the way i paln on doing it is using the exhaust as my vaccuum and running 2 ports from the VC i plan to keep the port for the exhaust above the 2 ports coming from the VC to lower the chance of it sucking oil into the exhaust and then putting a check line in the line running to the exhaust.
this catch can wont have a breather on it either
Old Feb 8, 2011 | 05:16 PM
racebum's Avatar
see i get this, with a sealed system you're using airflow to create vacuum on the line. how much vacuum this really creates is something i'm not sure of. the vented systems make sense but not when you add vacuum...i mean you're venting the vacuum to the atmosphere. what makes the absolute most sense is a vacuum pump rigged up where the AC is. then you would not only gain hp, you would make 100% sure you don't have positive pressure anywhere
Old Feb 9, 2011 | 08:42 AM
olddohc's Avatar
where the heck can i find just a stock catch can for my 90 teg?
Old Feb 9, 2011 | 12:01 PM
racebum's Avatar
stock uses the pcv system, what are you asking exactly?
Old Feb 9, 2011 | 08:19 PM
olddohc's Avatar
i need that piece on the back of the block that catches oil, i think it might be called a breather box, its black and recangular in shape and has a hose or two attached to it
Old Feb 10, 2011 | 01:04 AM
racebum's Avatar
well, you would need to go to honda or acura and order one, it is a breather box which they will show as part of the pcv system. there is another way around it though. you can block that off and run an endyn style catch can
Old Feb 13, 2011 | 04:37 AM
B&R
Old Feb 13, 2011 | 05:23 AM
Nick_p's Avatar
ok i see a lot of replies here.
i see the diagram.
i already drive the valve cover fitting AND the PCV port (without the 90* PCV valve) to the inlet of oil catch can.
and the outlet of the oil catch to the pre-turbo intake pipe.
I did this because i think if i use breather filter to valve cover fiting maybe smels bad in the cabin.
is this way wrong to a turbo B16 engine??
Andrew99911
Honda Civic (2001 - 2005)
Jul 5, 2017 11:46 AM
integra_101
May 24, 2013 11:07 AM
accord1986
Apr 5, 2012 02:22 PM
big-cat
Jun 21, 2007 06:09 AM
mafiaboy757
Sep 14, 2005 08:58 AM
